plug or patch a tire? which is better?
Old Oct 26, 2004 | 06:15 PM
GSblueRacing's Avatar
Default plug or patch a tire? which is better?
Got a slow leak in my rear tire(probably from a nail/screw), had to fill air every 3 to 4 days. tire still have 65 % thread. So should I bring it to a patching shop or a plugging one? any pros and con of using either?... ..I just use my car for daily commutes... don't go on tracks.
thanks
Modified by GSblueRacing at 5:38 AM 10/27/2004
Old Oct 26, 2004 | 06:35 PM
miketegra's Avatar
Default Re: plug or patch a tire? which is better? (GSblueRacing)
um...............plug?
Is there a difference between a "patch" and a "plug" ?
yourmom25's Avatar
i like to patch it because it overshoots the hole to make sure the hole is completely shut. a plug may leave a little room for leakage although a plug is sufficient if done properly.
also the patch costs a little more and i like to think that i pay for what i get.
Old Oct 26, 2004 | 06:42 PM
O3ASEVO's Avatar
Default Re: plug or patch a tire? which is better? (yourmom25)
for a leak use a patch. I work at ATC (americas tire co).
Old Oct 26, 2004 | 07:14 PM
Echo7847's Avatar
Default Re: plug or patch a tire? which is better? (SlammedDC4)
Patch is safer
Old Oct 26, 2004 | 07:17 PM
khunt0012's Avatar
Meat Robot Invisible
Default Re: plug or patch a tire? which is better? (Echo7847)
Patch that ****, that's all we offer at Acura.
Old Oct 26, 2004 | 07:51 PM
Honda Hick's Avatar
I've used plugs a few times for nails in my tires. They all held good and never leaked on me. That's just my experience.
Old Oct 26, 2004 | 08:25 PM
O3ASEVO's Avatar
Default Re: plug or patch a tire? which is better? (Honda Hick)
plugs are good for nails, screws ect...but for small leaks the patch is better.
Old Oct 27, 2004 | 01:05 PM
btownteg
Guest
Posts: n/a
if you use a plug make sure you ream out the hole very well before inserting the plug. this will prevent the steel belts from cutting it and making it worthless.
Old Oct 27, 2004 | 01:20 PM
Redtail's Avatar
Default Re: plug or patch a tire? which is better? (btownteg)
ream out the hole....hehehe....
Old Oct 27, 2004 | 02:41 PM
xprohx's Avatar
I think too much
Default Re: plug or patch a tire? which is better? (Redtail)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlammedDC4 &raquo;</TD></TR><TR><TD CLASS="quote">for a leak use a patch. I work at ATC (americas tire co). </TD></TR></TABLE>
I took my car to america's tire co. to get my tire leak fixed, and they said they couldn't patch/plug it for some reason. I had insurance on the tire so i got one brand new tire for $27 (kuhmo 712). I brought the car in and they replaced the wrong tire
Old Oct 27, 2004 | 06:02 PM
O3ASEVO's Avatar
Default Re: plug or patch a tire? which is better? (xprohx)
well then that ATC sucks...if they said they couldn't plug/patch it, it could have been a leak in the side wall. Anything in the side wall in non repairable.
Old Oct 27, 2004 | 06:12 PM
eg6_vx's Avatar
use a patch-plug like this http://www.mz3.net/articles/156.html . they work great. that's all we use at tires plus where i work
Old Oct 27, 2004 | 06:52 PM
b-power's Avatar
patch depending on the tire cost. if cheap buy another one.
Old Oct 27, 2004 | 07:26 PM
marsbike's Avatar
From: Salt Lake City, Chicago at heart, UT or IL, USA
Default Re: plug or patch a tire? which is better? (b-power)
What about slime? Would that work?
Old Oct 27, 2004 | 08:17 PM
derrick2237's Avatar
In my experience plugs have worked better than patches.
Old Oct 27, 2004 | 10:12 PM
xprohx's Avatar
I think too much
Default Re: plug or patch a tire? which is better? (derrick2237)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marsbike &raquo;</TD></TR><TR><TD CLASS="quote">What about slime? Would that work?</TD></TR></TABLE>
I think that sutff leaves a residue on you tires.
Old Oct 27, 2004 | 11:39 PM
LostGsr's Avatar
Default Re: plug or patch a tire? which is better? (marsbike)
Don't ever use that slime crap. It will throw your tire off balance, resulting in unwanted road noise.
Old Oct 28, 2004 | 09:30 PM
marsbike's Avatar
Default Re: plug or patch a tire? which is better? (LostGsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LostGsr &raquo;</TD></TR><TR><TD CLASS="quote">Don't ever use that slime crap. It will throw your tire off balance, resulting in unwanted road noise.</TD></TR></TABLE>
Ahhhh didn't know that. I thought it would dispurse evenly and dry and such... Oh well. I can't tell in my DH bike. Those tires and tubes are held together with slime and a prayer.
Old Oct 28, 2004 | 09:45 PM
Sukebei Oni's Avatar
- plugs are faster and easier since you don't have to remove the tire from the wheel, or even take the wheel off the car in some cases.
- a patch requires the removal of the tire from the wheel in addition to a somewhat skilled patcher to do it right. its pretty easy to screw up a patch if you don't know what your doing.
I've seen people rush a patch job and have to do it over a couple times and it still wouldn't hold air, so i had to do it for them. ( yes, yes, i know they're idiots)
- also a patch is good for when you have 2 holes close together, like from a big staple. It can cover both holes at the same time.
- overall I would prefer the patch as the most effective way to repair a leak. i once had a nail go into the sidewall in one of my New 215/35/18 tires and I wasn't about to buy another knew tire. So I patched the hole that was in the sidewall, and its still holding air for more than a year now. ( and theres not much sidewall to patch on a 215/35/18 )
Old Jun 29, 2005 | 08:17 PM
BLUE EH3's Avatar
Help we my pennies
Default Re: plug or patch a tire? which is better? (eg6_vx)
Z Rated Tire Patch-Plug
Not soon after recovering from the expense of new M roadster tires I discover a nail embedded in the tread. I immediatly remembered previous debates of patching vs plugging damaged tires. Both solutions appeared to work but in either case you technically lost the Z rating on the tires. If you've got a lead foot this loss of rating can be concerning to say the least.
When I brought my problem and concern to the attention of a tire repair shop, I was happy to find a solution. Pictured to the right is a Z Rated Patch-Plug. I have no idea who makes it or any other details, but the tire shop made it sound like a fairly common item they use whenever repairing a Z rated tire.
The tire tech broke down the tire and removed the nail. The patch-plug and area around the hole inside the tire were cleaned and then coated with what I assume to be a thick glue substance. The pointy end of this patch-plug is threaded through the hole the nail left, until the patch (round part at the bottom of the picture) makes contact with the inside of the tire. You end up with what appears to be a nail sticking out of your tire. The tire tech snipped off the protruding section, put the tire back together and then rebalanced it. I was told to take it easy on the tire for a day and then consider the tire "good as new".
Note: I did not ask permission to publish the name of the tire repair shop. Previous experience in publishing information on ///MZ3.Net has taught me to error on the side of caution, so the actual name is withheld but your local BMW dealership should be able to repair the tire or find someone who can.
Update: It's been three months and the tire has preformed well. While I don't want to incriminate myself, lets just say that I have full confidence in the Z Rating of the patch/plug
Old Jun 30, 2005 | 02:57 AM
Dee A Nine's Avatar
Default Re: plug or patch a tire? which is better? (BLUE EH3)
Just replace the tire if you seem too concerned, again, better to be safe than find out to be sorry later.
Old Jun 30, 2005 | 05:54 AM
1Cloudwalker1's Avatar
discount tire co. plugged mine on my previous car, rhode on it for months, no problems, it's still on there infact
NY_2_OC
Dec 19, 2011 12:01 PM
ginahoy
Honda CR-V & Element
Dec 13, 2010 04:24 PM
cilvia
May 4, 2007 05:01 AM
96IntegraLS4DR
May 3, 2007 05:01 PM
indy
Jul 16, 2001 05:46 PM
