piston ???
Old Apr 12, 2005 | 04:16 PM
Battle Cat's Avatar
B A N N E D
Default piston ???
I have a b20 in my integra, can i put higher comp. piston on my stock rods ???
Old Apr 12, 2005 | 04:35 PM
IggyBcool's Avatar
wuptido on the b20... yes u can put higher compression on the stockers but it would be a whole hella better and safer and more reliable if u upgrade the rods.. it also depends on how many miles are on the stockers
Old Apr 12, 2005 | 10:25 PM
Battle Cat's Avatar
B A N N E D
Default Re: (99LStegra)
what would be the highest compression i could go on the b20 ??? for a daly driver !!!
Old Apr 12, 2005 | 10:26 PM
Battle Cat's Avatar
B A N N E D
Default Re: piston ??? (Battle Cat)
would any one know ???
Old Apr 12, 2005 | 10:29 PM
Kendall's Avatar
There aren't any high compression "off the shelf" pistons for the B20's. Your only real option is to use B20Z pistons if you have a B20B block and still your compression is quite low. Your stock rods will have to be modified to allow forged high compression pistons to work with them, it'd be easier and less time consuming to buy some aftermarket rods.
Old Apr 12, 2005 | 10:51 PM
Battle Cat's Avatar
B A N N E D
Default Re: (Kendall)
do you know what kind of piston amd rods i should go with to keep it daly dirver ?? higher compression or same ??? because i think about b20/vtec
Old Apr 12, 2005 | 11:22 PM
Kendall's Avatar
Make up your mind about putting a VTEC head on it before you even start to choose internals.
Old Apr 12, 2005 | 11:24 PM
riceball777's Avatar
any machine shop can make stock pistons piut aftermarket forged rods for a very small price
lots of ppl get forged pistons and stock with stock rods and just upgrade to arp rods bolts
Old Apr 13, 2005 | 08:43 AM
Uncle Ben's's Avatar
Cogent Argument Enthusiast
have you taken your car to the track, riceball777? i was just wondering because your lsvtec setup is similar to what i plan on doing this summer, and i wanna know what i can expect.
Old Apr 13, 2005 | 10:25 AM
Battle Cat's Avatar
B A N N E D
so i should get the head first and then the piston ???
eccentrix
Mar 22, 2015 08:09 AM
EGG_y0
Jun 17, 2009 10:04 AM
tbsol
Oct 15, 2004 09:18 PM
blackassasin95
Sep 20, 2004 06:28 PM
NeedMOPower
May 3, 2002 11:33 AM
