passwordJDM
Old Sep 28, 2004 | 11:44 AM
SmurfDA's Avatar
From: I live in a town with Boston traffic, mass, united states
Default passwordJDM
was just looking under there complete swaps and such, and saw that there selling complete CTR swaps for 3999.99, cheaper then then the 96 jdm itr swap and cheaper then the 98+ ITR swaps on there site, but anyways, is the wireing any different on the b16b as opposed to a b16a2? just curious, might get one for the DA track *****.
Old Sep 28, 2004 | 01:20 PM
SmurfDA's Avatar
Default Re: passwordJDM (93TealSi)
anybody?
Old Sep 28, 2004 | 01:29 PM
SmurfDA's Avatar
52 views and not one person can tell me about wireing differences, if there is any
Old Sep 28, 2004 | 02:50 PM
user 996328629's Avatar
Im sure it is, but please dont put a b16 into a integra
Old Sep 28, 2004 | 06:58 PM
SmurfDA's Avatar
Default Re: passwordJDM (Swags04)
ill do what i want, when i want to my car, thank you, and its a CTR motor, not a normal b16, its a destroked ITR motor
Old Sep 28, 2004 | 07:01 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93TealSi &raquo;</TD></TR><TR><TD CLASS="quote">ill do what i want, when i want to my car, thank you, and its a CTR motor, not a normal b16, its a destroked ITR motor
destroked = less TQ
Youll regret it thats all.
Honda's already beg for some TQ, why give it a motor that can barely produce 100 tq....
when for almost the same price u can get a b18c
Old Sep 28, 2004 | 07:04 PM
kNOwLedGeDA9
Guest
Posts: n/a
NICE!!!!!!!! The wiring is no different from any other B16A...the difference is that the B16B will be OBD II. You will want to convert the car to OBD I. Use OBD I distributor, injectors, and ECU and it will fire right up. Don't listen to B16A haters, the DA was made for the B16...I'd rather trust Honda than that guy
Old Sep 28, 2004 | 07:09 PM
kNOwLedGeDA9
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Swags04 &raquo;</TD></TR><TR><TD CLASS="quote">
destroked = less TQ
when for almost the same price u can get a b18c</TD></TR></TABLE>
Well, that is true but how much torque does a B18C (non R) make above 7,200 RPM? After the engines peak torque RPM, torque output falls. The B16B makes it peak torque quite a bit higher than the B18C's 7,200; so in the engine's main powerband (7,500 -8,500 RPM) they make similar torque numbers. This is why he wants to use the B16B on the track. If he were drag racing I would recommend the B18C but on the track, peak HP and short gears of the B16B rule.
Old Sep 28, 2004 | 07:16 PM
SmurfDA's Avatar
Default Re: passwordJDM (kNOwLedGeDA9)
thank you, if all goes well at the bank tomorrow, motor should be on its way *crossing fingers*
Old Sep 28, 2004 | 08:48 PM
theSYNDICATE's Avatar
From: Derek Jeter drinks wine coolers,, The Nation, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kNOwLedGeDA9 &raquo;</TD></TR><TR><TD CLASS="quote">
NICE!!!!!!!! The wiring is no different from any other B16A...the difference is that the B16B will be OBD II. You will want to convert the car to OBD I. Use OBD I distributor, injectors, and ECU and it will fire right up. Don't listen to B16A haters, the DA was made for the B16...I'd rather trust Honda than that guy </TD></TR></TABLE>
Thank you, they came with them stock in Japan for gods sake.
Old Sep 28, 2004 | 08:52 PM
Most likely because all they had was a b17a
Old Sep 28, 2004 | 10:22 PM
kNOwLedGeDA9
Guest
Posts: n/a
B17A is just a bastard B16A that was barely stroked and has absolutely no dome in its pistons. I guess Honda of Japan didn't trust Americans to put premium gas in their cars back in those days...now that i think about it...they still put "premium unleaded fuel only" in DC2 GS-R's gauge clusters, yet they still only had 10:1 compression.
Old Sep 28, 2004 | 10:29 PM
esponet's Avatar
just for kicks i can get you a 96spec itr motorswap for $3900
http://www.d2motorsports.com
but to answer your question. as long as you have a running integra yoou could use your stock eng. harness and just add the folowing, vtec solenoid, vtec oil preasure switch*,knock sensor.
*96+all jdm b serries motors don't have vtec oil preasure switch. if you use the jdm ecu then you don't need it. if you use usdm ecu you will need to replace the vtec solenoid for one with a oil sensor, or use a vafc or something the same that will bypass the sensor missing.
phaiwezzie
May 10, 2018 11:08 AM
Rev2 9K
10
Sep 28, 2005 07:02 AM
theslugbug
10
Oct 27, 2003 03:30 PM
Irishweird00
49
May 14, 2003 03:14 PM
Looose_R
17
Jul 26, 2002 06:27 PM
