oxygen sensor for emission
can anybody tell me where this oxygen sensor in the picture located at? im living at a place that are really cold right now,and dont have a garage to take it out...
is this located at the CATALYTIC CONVERTER...need answear ASAP for inspection test.....
http://i4.ebayimg.com/02/i/06/24/46/c7_1_b.JPG
there is only one o2 sensor on your car (if it is a 94-95) and yes it is located on the top of the cat. There is no way to tell from the picture you provided otherwise. If your car isn't lowered you can drive one side of the car up on curb and you should be able to reach it that way.
Modified by Thepanda at 1:53 PM 3/3/2006
obd1 cars have only 1 sensor located on the header collector or the front of the catalytic converter. If you have an obd2 car, the you will have a second one after the the cat as well. I prefer to buy plug n play sensors rather than soldering that one to the stock plug.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .xcalibur. »</TD></TR><TR><TD CLASS="quote">obd1 cars have only 1 sensor located on the header collector or the front of the catalytic converter. If you have an obd2 car, the you will have a second one after the the cat as well. I prefer to buy plug n play sensors rather than soldering that one to the stock plug.</TD></TR></TABLE>
I read both posts and I am scratching my head. I am OBD2 and have two O2 sensors in my cat Primary and secondary. OBD 1 Hondas have 2 sensors 1 primary and secndary one in the header and 1 in the cat. Can someone clarify this?
ok now i can tell u guys use to took it of,but now my question is how many wire does it have???i got a Bosch Oxygen Sensor that i just recieved from ebay it have 4 wire....but i tought it only have 2 wire coming out before the connecting part...its to damn cold over here so i dont wanna have problem when im fixing it...yes i got a OBD1 94 GSR. can anybody point me a picture or answear...Thanx guys
i have ob2 just replaced my pre-cat sensor.. it had four wires and i got the bosch as well. if u have a oem one there already take it out cut the wires so u can use the harness and then splice ur bosch to them. it shoulda came with a write up i dont remember what colors go to what but i remember that it was type tthree on the paper
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lan »</TD></TR><TR><TD CLASS="quote">
I read both posts and I am scratching my head. I am OBD2 and have two O2 sensors in my cat Primary and secondary. OBD 1 Hondas have 2 sensors 1 primary and secndary one in the header and 1 in the cat. Can someone clarify this?</TD></TR></TABLE>
OBD1 integras do not have a secondary sensor. they only have one in the cat. there is no sensor in the header for an OBD1 integra. (years 94-95)
