Overheating problem
Old Mar 13, 2008 | 05:46 PM
JDM215's Avatar
Default Overheating problem
I have a 94 ls and after about 5 mins of driving it over heats i was on the high way and the car over heated and turned off i open the hood one of my hoses bursted and coolant was everywhere after i fixed the hose i was told to change the thermostat so i changed it and the oil light always comes on and changed the oil light still comes on and still overheats i put more coolant got a new radiator cap did everything to stop overheating but it still happens i was told maybe the motor is knocking but im not sure can u help me im about to cry because of this car hah
Old Mar 13, 2008 | 06:22 PM
BoSox46GSr's Avatar
Default Re: Overheating problem (JDM215)
Oil light might be coming on due to bad oil pressure. This might be caused by a blown headgasket. How many times did you let it overheat?
Old Mar 14, 2008 | 12:55 PM
JDM215's Avatar
Default Re: Overheating problem (BoSox46GSr)
the first time was in the high way when the car totally shut off second time was when i replaced the hoses and thermostat 3rd time was when i changed the oil bought a new radiator cap and flushed the radiator so i only let it overheat about 3 times
Old Mar 14, 2008 | 01:00 PM
yc_dc4mar's Avatar
three time!
your head is probably warped or something. are you smoking? does it smell like ***?
you might have burnt up all your oil.
i would pull the head and check for any damage. i overheated and also burnt a hole in one of my exhaust valves. change the gaskets. do oil change. drain, flush and refill radiator. make sure all your hoses are good. check thermostat.
are you throwing a CEL? if so check the code.
Old Mar 14, 2008 | 02:28 PM
ehhhdc2's Avatar
* B A N N E D *
Default Re: Overheating problem (yc_dc4mar)
when you guys say overheating does it mean the temp gauge moves to H or its climbing then you turn the motor off?
Old Mar 15, 2008 | 02:27 PM
JDM215's Avatar
Default Re: Overheating problem (ehhhdc2)
found out the motor was knocking so im just buyin a new motor
Jon Petersen
Jul 22, 2018 12:04 PM
aristo808
Jan 31, 2012 05:31 AM
profesional-hobo
Apr 17, 2009 07:28 AM
copsloveme
Dec 3, 2006 02:11 PM
vc
Apr 4, 2006 06:44 AM
