overheating....
Old Mar 17, 2006 | 09:08 PM
PyeeK's Avatar
Default overheating....
so im drivin and look at the temp gauge and it goes almost all the way to the top, so i turned on the heat and it went back down...but i kept driving and again it went back to almost the top and then fell back down to the middle....it was doing this all day, gonna check the themosat tomarrow...anything else i should check for????
Old Mar 17, 2006 | 09:17 PM
god.loves.ugly
Guest
Posts: n/a
Default Re: overheating.... (rotate-da)
coolant.
Old Mar 17, 2006 | 09:28 PM
EgxHaTcHxGsR's Avatar
Default Re: overheating.... (Kind_of_a_big_deal)
are u leaking coolant? u should check for that... i did this before when i'm idling it goes up but when driving it goes back down..
Old Mar 17, 2006 | 11:44 PM
PyeeK's Avatar
Default Re: overheating.... (EgxHaTcHxGsR)
Old Mar 17, 2006 | 11:55 PM
suzawa94's Avatar
common causes of overheating:
-air in system (bleed air from system)
-external leaks (visual inspection-etc. rad., water pump. cap, hoses)
-fans not coming on (bad relay or circuit)
-dirty coolant (drain and fill system with new coolant)
-blown head gasket (inspect oil and coolant for mixture)
-thermostat stuck closed (upper hose will still be cold upon normal op. temp)
Jayzdb1
Acura TL, RL & ZDX
Aug 1, 2011 06:05 AM
tianporn
Feb 26, 2011 10:58 PM
Uncle Ben's
Mar 25, 2010 10:27 AM
msinsky14
Jul 10, 2009 01:34 PM
ThaSpitefulWun
Apr 5, 2004 09:17 AM
