ONE MORE!
Old Aug 28, 2006 | 02:49 AM
dmckrazy45's Avatar
Default ONE MORE!
okie.. i went to get the emission test and i failed due to... 02 Sensor Heater Circuit Bank 1 Sensor 2??? Have no idea what that means.. but is it the catalytic converter? cause mine has no 02 sensor in it... do i just need to purchase one with a 02 sensor port and install it.. should i be fine then???
thanks!!!
Old Aug 28, 2006 | 04:51 AM
atg1290's Avatar
Some more details would help..Year and model. If it is supposed to have one and you dont have one installed then thats your problem..
Old Aug 28, 2006 | 05:57 AM
Kiniku Chunks!!!
Guest
Posts: n/a
Default Re: ONE MORE! (dmckrazy45)
What r you running? What mods do you have, and mostly important whats the year of the car?
Is the car in perfect running condition?
Old Aug 28, 2006 | 03:19 PM
dmckrazy45's Avatar
Its a RS 2 door 1997.. all i have is intake headers and exhaust...
Old Aug 28, 2006 | 03:40 PM
gsrob's Avatar
Default Re: (dmckrazy45)
You need to have an O2 sensor to pass smog. Is there a check engine light? Did someone just unplug yours and leave it out?
Old Aug 28, 2006 | 04:32 PM
slowly slipping away's Avatar
to answer your question, yes -there should be an 02 sensor at the cat. Weather this will solve your problem I couldnt say -good luck
vtechappy
Jun 25, 2010 09:59 AM
kbw2000civicex
27
Nov 6, 2008 07:27 AM
Zimmerman
Aug 5, 2006 12:17 PM
breathinez
Aug 18, 2004 09:20 AM
silver ek
14
Jan 24, 2004 11:53 PM
