OH BOY....HELP......i gots PROBLEMS
Old May 25, 2003 | 08:22 PM
TeG-DiS's Avatar
Default OH BOY....HELP......i gots PROBLEMS
wellz...i think every one knows the answer except me....just getting in to dis mech thing...wellz i got a '92 integra RS 2dr hatch ......... here it go
FIRST PROBLEM
I was changing my spark plugs and i found oil on it...it was my 2nd and 3rd plugs that had oil on it.....the 1st and 4th is all clean....whats the problem??
SECOND PROBLEM
I just recently change my right and left axle.....now its making all this rattling sound when i start it up in da morning....sounds like my axle is hitting something...but i notice that it goes away after i drive around a bit.....when me and my frwend put it in it was hard but it took time....need ideas on what is wrong with my axles???
Old May 25, 2003 | 08:32 PM
00VTEC's Avatar
Default Re: OH BOY....HELP......i gots PROBLEMS (TeG-DiS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeG-DiS &raquo;</TD></TR><TR><TD CLASS="quote">wellz...i think every one knows the answer except me....just getting in to dis mech thing...wellz i got a '92 integra RS 2dr hatch ......... here it go
FIRST PROBLEM
SECOND PROBLEM
I just recently change my right and left axle.....now its making all this rattling sound when i start it up in da morning....sounds like my axle is hitting something...but i notice that it goes away after i drive around a bit.....when me and my frwend put it in it was hard but it took time....need ideas on what is wrong with my axles??? </TD></TR></TABLE>
oil fouled plug usually means, worn rings, scored cylinder or leaking valve seals.
i recommend doing compression test
Old May 25, 2003 | 08:39 PM
DK4200's Avatar
Default Re: OH BOY....HELP......i gots PROBLEMS (00VTEC)
change the valve seals, THEN do a compression test
Old May 25, 2003 | 08:55 PM
TeG-DiS's Avatar
thanx peeps...ill check it out.....ne thing about my axles??
Old May 25, 2003 | 09:42 PM
Bspec18's Avatar
are you sure its your axles and not your valves ?
Old May 25, 2003 | 11:30 PM
TeG-DiS's Avatar
ummm.....i denno....can i be my valves??......im so new to dis...
Old May 26, 2003 | 01:21 AM
slimbo's Avatar
there are these washer things (nice technical term there hey ) that seal the sparkies. they do stop sealing them properly after a while, then you start getting oil on the thread and tip of the plug.
the washers are cheap as chips... and it stopped the problem in my car.
and yes, when i posted the same question here a while ago everyone was telling me my rings were fuxxed, scored cylinder walls etc...
give the washer things a go before you start getting all paranoid
i paid $8 AU each... which is like $5US, and you only need four of em.
best of luck to ya!
*** not promising it will fix the problem mind you, but give it a try hey
Old May 26, 2003 | 01:49 AM
TeG-DiS's Avatar
Default Re: OH BOY....HELP......i gots PROBLEMS (slimbo)
where are these washer things??......never heard of it before....
CARflyGUY
May 30, 2007 07:20 AM
QuAcK5dC2
Aug 17, 2006 08:11 AM
Flux
Apr 23, 2005 08:25 PM
drewbie
Jul 14, 2004 03:48 AM
hitvtecgetloud09
Nov 28, 2003 03:32 PM
