which offset for 16x7 wheels?
Old Sep 6, 2004 | 01:45 PM
1zach4's Avatar
Default which offset for 16x7 wheels?
I'm looking at getting some work nezart spoke 2's in 16x7 but im not sure which offset to get.
I can get +42, +38, or +28
I wan't a nice sized lip, but I don't want the wheel to stick out from the wheel well. Any help would be greatly appreciated, pictures would help even more.
Old Sep 6, 2004 | 01:47 PM
reza
Default Re: which offset for 16x7 wheels? (1zach4)
38's
Old Sep 6, 2004 | 02:03 PM
1zach4's Avatar
Default Re: which offset for 16x7 wheels? (Reza")
just wondering why you picked the +38....I don't completely understand offsets. All I can put together is that lower offset = bigger lip
and I also want to fit a 12.2" wilwood brake kit under these wheels.
Old Sep 6, 2004 | 02:08 PM
jojoforhelp's Avatar
The 42 or 38 are the ones that will work. The 28 will stick out too far and hit the fender under suspension "squaut".
Old Sep 6, 2004 | 02:38 PM
1zach4's Avatar
Default Re: which offset for 16x7 wheels? (jojoforhelp)
what will the noticeable differences be in the +42 and +38? And they'll both fit the 12.2" wilwood kit?
Old Sep 6, 2004 | 02:52 PM
You wont feel a noticeable difference....
If its just for the street, it really wont matter.
Are you using your stock caliper or wilwoods caliper?
If you want some basic info on offsets, go to the tire rack. http://www.tirerack.com
Old Sep 6, 2004 | 03:16 PM
1zach4's Avatar
i'll be using wilwood's caliper, thanks for the link
Old Sep 6, 2004 | 04:12 PM
I would contact Wilwood and they should have a spec sheet they can fax you on the sizes and what you may need.
Old Sep 6, 2004 | 04:25 PM
1zach4's Avatar
Thanks, I just sent them an e-mail.
It says that it requires at least a 16" wheel, but I think the offset might cause a problem with the wilwood calipers.
Old Sep 7, 2004 | 05:28 PM
1zach4's Avatar
Alright I was given this link
http://www.wilwood.org/ds476.pdf
I was told to check the clearances, and i'm not quite sure how to given the instructions given in the link for the specific brake kit i'm purchasing.
Can anyone help me out here in figuring out if the brakes will fit my wheels, or which offsets will fit and which ones won't?
Old Sep 7, 2004 | 06:20 PM
Your going to have to find the wheels you want and contact the manufacturer. Get their specs on the wheel and compare the two.
Old Sep 7, 2004 | 06:47 PM
1zach4's Avatar
the wheels I want are in the first post
16x7 Work Nezart Spoke 2's with either a +42 +38 or +32 offset (whichever will fit if any of them do)
Old Sep 8, 2004 | 10:23 AM
1zach4's Avatar
bump
Old Sep 8, 2004 | 06:18 PM
1zach4's Avatar
up
TryllZ
Honda Civic (2006 - 2015)
Sep 14, 2013 04:26 PM
SOLOITR2001
Sep 22, 2009 07:10 AM
teejlc
Sep 13, 2008 09:39 PM
EvDog03
Honda Civic (2001 - 2005)
Sep 6, 2008 06:48 PM
(JON)
Aug 19, 2004 02:33 PM
