OBD2B to obd1 CEL codes
Old Feb 2, 2010 | 03:12 PM
Swoops's Avatar
Default OBD2B to obd1 CEL codes
i have obd2 gsr head on what i believe is a obd1 gsr block
i have an obd2b to obd1 jumper harness.
i tried to check my codes manually
i think it kept giving me
codes 7, 8 , & 9 and it kept repeating them
please give me some real help..my car is idling crappy
Old Feb 2, 2010 | 04:06 PM
Sumslapper's Avatar
Year 3030
Default Re: OBD2B to obd1 CEL codes
7 TPS - throttle position sensor
8 TDC - top dead centre sensor
9 CYP - cylinder sensor
Sounds like your timing is way off. Check the cam timing before you blow the motor. Being a tooth off will cause a bad idle.
All-Motor-Junkie
Jul 15, 2009 07:44 PM
rick_rabies
15
May 28, 2009 04:36 PM
mgags7
Mar 15, 2008 09:18 PM
mgags7
Sep 5, 2007 10:19 AM
7808
Apr 16, 2007 09:36 PM
