OBD2a and OBD2b difference?
Old Jul 17, 2005 | 09:02 AM
illuzi0nz's Avatar
Default OBD2a and OBD2b difference?
Hey guys, I'm about to do a JDM type r motor swap into my car and I'm doing the research I need before I begin the process. I know that I need a harness to convert from OBDI to OBDII. But then I just realized that there are OBD2a and OBD2b. Do JDM type r engines run on a OBD2a or OBD2b ECU? SHould I buy the OBDI to OBD2a or OBD2b? Thanks all
Old Jul 18, 2005 | 03:51 AM
PaChiLa Leader's Avatar
Default Re: OBD2a and OBD2b difference? (illuzi0nz)
96-01 JDM ECUs are OBD2A
what year is your car?
year of the B18C you are getting?
need more info.
Search key is your friend and you should really use it
Old Jul 18, 2005 | 06:24 PM
illuzi0nz's Avatar
Default Re: OBD2a and OBD2b difference? (PaChiLa Leader)
my car is a 1995 LS. The engine I'm about to order is 98+. Tried searching, but couldnt get the answer I needed. Thanks fer your help PaChiLa Leader
Old Jul 18, 2005 | 08:28 PM
SuzukaBlueAP2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by illuzi0nz &raquo;</TD></TR><TR><TD CLASS="quote">my car is a 1995 LS. The engine I'm about to order is 98+. Tried searching, but couldnt get the answer I needed. Thanks fer your help PaChiLa Leader</TD></TR></TABLE>
to put the vtec ecu in your non-vtec chassis, you'll either have to run some wires yourself or buy a harness that is pre-made for that conversion.
Old Jul 31, 2005 | 09:22 AM
90teg's Avatar
bump cause i wanna know the difference too
12stepdCivic
Jan 16, 2012 07:38 PM
yahtzee530
Sep 29, 2008 11:55 PM
TRQLESS
16
Feb 3, 2008 08:05 PM
iceman7329
10
Apr 25, 2007 07:18 PM
kyn
Oct 14, 2003 09:09 AM
