obd1 / obd2 head
Subscribe
Jul 30, 2004 | 08:35 PM
Will it be perfectly ok to swap an obd1 head to an obd2 motor? The reason im asking is that i recently did that and the vtec does not seem to work... i get a code 22. Vtec oil pressure switch but its working fine. TIA
Reply 0
Jul 31, 2004 | 12:38 PM
Re: obd1 / obd2 head (96tegsr)
bump
Reply 0
Jul 31, 2004 | 12:59 PM
Did you make sure to use the right sensor? You should probably use the sensor from the OBD2 motor if it will fit.
Reply 0
Jul 31, 2004 | 04:50 PM
Re: (Octoman)
i believe its the same... correct me if im wrong
Reply 0
Subscribe
