obd1 B20
Old Mar 27, 2012 | 08:21 PM
94DB7integra's Avatar
Default obd1 B20
So I have a obd1 p28 ecu, obd1 harness, and obd1 b20 block, my check engine light code is reading that a problem with the crank angle sensor but obd1 b20's don't have crank angle sensor's. I am wondering if there is a way I could bypass that code or something I could do to make the engine light to go away?
Old Mar 27, 2012 | 08:27 PM
el crapitan's Avatar
Default Re: obd1 B20
b20's are all obd2
what's the exact code you're throwing?
Old Mar 27, 2012 | 08:44 PM
It's reading code 4 which is crank angle sensor, and i have researched it and i found that they don't have crank angle sensors?
Old Mar 27, 2012 | 10:43 PM
you have a crank position sensor (ckp) located in the distributor. there will be a crank fluctuation sensor (ckf) located on the oil pump housing. but that's irrelevant since you won't have that connected and your obd1 ecu won't be looking for it.
you can not bypass the ckp. not that i'm aware of anyways
which distributor are you using?
Old Mar 28, 2012 | 03:30 PM
Im not sure what dizzy im running, but yeah ive looked for the plug on my harness for the ckf and thats not there, i know i don't have the correct dizzy though because one of the bolts doesnt match up with my head. i have a b16 and im pretty positive it's obd1 or else my harness wouldn't work with it.
Old Mar 28, 2012 | 09:31 PM
you need an integra distributor. non vtec
Old Mar 29, 2012 | 07:03 AM
But i have a vtec head? That doesnt matter?
Old Mar 29, 2012 | 07:07 AM
freaks_smk91's Avatar
sounds to me like you need an obd1 dizzy
Old Mar 29, 2012 | 02:42 PM
OhGeeRize's Avatar
is yur ecu chipped?
Old Mar 29, 2012 | 03:45 PM
B20ztek's Avatar
If you dont have a B16 vtec distributor then that is your problem.
Old Mar 29, 2012 | 08:06 PM
whoops. sorry. didn't see that. whatever distributor you have on there is not the correct one for the head,clearly.
get the correct distributor for that head and ecu
Old Mar 29, 2012 | 08:53 PM
Ohhh i see i see, thanks guys i will try try that asap, and no OhGeeRize the ecu is not chiped or tuned but i have a chip for it that i will be having put in and tuned so it runs better
sikcrx80
May 1, 2023 05:16 PM
Bangher4$
Oct 17, 2009 06:40 AM
sikcrx80
May 19, 2007 05:31 PM
kbouchard1092
Jan 18, 2007 05:23 PM
JDM96SpecCTR
Mar 5, 2005 11:03 AM
