obd0 to obd1 conversion help
Old Feb 23, 2009 | 04:09 PM
xsi90teg's Avatar
Icon6 obd0 to obd1 conversion help
I have a 90 teg with a 89-91 jdm b16 swap. This past week i converted the car over to obd1 and im having a big issue. When i start the car it sounds like it runs strong and be fine but when i put it in gear and try to drive it has a hard time driving, like its running on 1 cylider. I bought a chipped ecu from a known place and i asked them what the problem could be and they are giving me the run around. I asked them if they set it for stock obd0 injectors and they said yes. But im thinking that it has alot to do with the injectors, feels like its not getting enough gas. the ecu isnt shooting any codes and im kinda lost. Well like really lost. If n e one has run into this problem or think they know the problem and could fill me in id appreciate it ALOT. Thanks
Old Feb 23, 2009 | 04:57 PM
xsi90teg's Avatar
Default Re: obd0 to obd1 conversion help
Bumpo
Old Feb 23, 2009 | 05:00 PM
ONE-CAM-EF's Avatar
check your injector wiring..also check your wires running from the dizzy..does it rev pass 4k? or it sounds like you have 2 step?
Old Feb 23, 2009 | 05:26 PM
xsi90teg's Avatar
well i had a 2 step programed in the ecu at 3k and it does that but when i drive it it can pass 4k i didnt touch the injector wiring and the dizzy wiring is fine.
tdbef
Oct 20, 2009 04:50 PM
nickeynick
Jun 29, 2009 08:52 AM
xsi90teg
Feb 19, 2009 12:28 PM
