obd0 to obd1
Old Mar 20, 2007 | 05:22 AM
hondateg10's Avatar
From: Somewhere in the United States, united states
Default obd0 to obd1
ok i have a 90 teg with a b16a swap. should i switch it over to obd1?
Old Mar 20, 2007 | 06:57 AM
DC2 Mang's Avatar
Default Re: obd0 to obd1 (hondateg10)
if you plan to modify the engine and get it tuned then yes
you will need an obd1 ecu, jumper harness and a 4 wire o2 sensor
Old Mar 20, 2007 | 07:41 AM
hondateg10's Avatar
is it better?
Old Mar 21, 2007 | 04:59 AM
hondateg10's Avatar
ttt
Old Mar 21, 2007 | 06:53 AM
DC2 Mang's Avatar
Default Re: (hondateg10)
yes, obd1 has better tuning capabilities
Old Mar 21, 2007 | 07:07 AM
brian L.'s Avatar
Default Re: (DC2 Mang)
no keep it obd0 now if you want a obd1 e.c.u. that would be cool just get a setp up harness.Your now stuck with the crapyness of obd0 i did do my boys whole 91 integra to obd1 but it's real hard.Now i did a 96 civic dx to 2000 si obd2 thats way EZer.Get a step up and go with a chiped p28 or go after market
Old Mar 21, 2007 | 07:32 AM
hondateg10's Avatar
ok... i just bought the hole set to convert to obd1 only thing i need is an ecu... im pulling the eng.. not just to do this do who ever did the swap before mr fucked it up so im redoing the entire swap... is it hard to to do the change(running the harness)?
Old Mar 26, 2007 | 09:10 AM
hondateg10's Avatar
ttt
Old Mar 27, 2007 | 03:42 AM
hondateg10's Avatar
ttt.... has ne one ever done this switch??? is it hard???
Old Mar 27, 2007 | 10:09 AM
hondateg10's Avatar
once again....ttt
ricardo13d
11
Dec 8, 2011 06:55 PM
efiliated
Jun 6, 2011 04:04 PM
tdubbebawllin
Mar 1, 2009 07:57 PM
xsi90teg
Jan 29, 2009 07:32 PM
lsvtec90
Nov 22, 2005 09:01 AM
