OBD II to OBD I conversion!
Quick question. I have a 95 GSR ECU and the harness, is there anything else that I need in order to make this changeover in my 2000 GSR?
Thanks for any replies in advance.
I was wondering the same thing. I don't think that it would take long to do b/c it's basically plug & play.
but for the OBD2V2 might meet a little problem with tach wire... which has no reading on RPM.... what you do is simply add a tach wire on it.. and problem fixed...
the whole conversion takes you like 2mins. to do it...
hahah a........ unplug the OBD2 ECU and connected the harness with the OBD1 and to your OBD2 engine HArness.. then you are ready to go...
i have done OBD2V2 myself it's pretty easy
prionailurus
Mar 25, 2008 12:28 AM
Its a direct plug and play if you have the conversion harness.
