Not Charging?
Old Jul 25, 2025 | 07:22 AM
Voyager97's Avatar
Default Not Charging?
Working on my fathers '95 SE 4 door. Car quitting while idling led me to discover the battery is not charging. Tested on battery and alternator, seeing less than 13 volts engine running.
Testing alternator input plug shows;
4.75 volts on White/Red Alt FR Signal
.04 volts on White/Green Alt Control
11.6 volts on Black/Yellow IG Power
11.6 volts on White/Blue Charge light
Car has 4 wire OBD2B plug.
(Test done engine off, key on)
Battery light is not illuminated with engine running.
I think there should be 12v on all those wires, could anyone point me in the right direction?
(Original alternator, 140k)
Thanks.
Old Jul 27, 2025 | 01:36 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: Not Charging?
Check the battery voltage with engine off. Should be at least 12.2VDC.
Start the car and check again. Voltage should jump up another 1.6V…..to around at least 13.8+. If not, replace the alternator and belt.
Ernesto Aragon
Jun 26, 2019 10:09 AM
timsimon
Honda Civic (2001 - 2005)
Jul 21, 2018 01:15 PM
willfly
Oct 13, 2015 09:15 PM
red civic standard
Mar 3, 2008 02:34 AM
OptimusPrimeX
Sep 23, 2006 10:54 AM
