NOOB Question: What type of engine is LS/VTEC?
Old Aug 8, 2005 | 07:32 PM
pat00gsr@yahoo.com's Avatar
Default NOOB Question: What type of engine is LS/VTEC?
I tried searching but only found results associating ls/vtec with something else, like turbo. But what is LS/VTEC? does it have anything to do with the integra ls?
I know it sstupid question, but I dont' know much about engine.
Old Aug 8, 2005 | 07:36 PM
Preferio's Avatar
Default Re: NOOB Question: What type of engine is LS/VTEC? (pat00gsr@yahoo.com)
SEARCH!!! And when you do, choose "Archived"... And yeah...
It's a non-vtec block with a vtec head on it... Why do you want to know? You're not going to try it are you? At least not anytime soon right?
Old Aug 8, 2005 | 07:40 PM
Preferio's Avatar
Default Re: NOOB Question: What type of engine is LS/VTEC? (95IntegraLSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95IntegraLSR &raquo;</TD></TR><TR><TD CLASS="quote"> You're not going to try it are you? At least not anytime soon right?</TD></TR></TABLE> I say that, because if you are having to ask what it is, because you heard it was a cool thing to do, and want to.... Don't until you have read up on it... And check out the FAQ in this forum... It has tons of links to really, really good information on the ls/vtec and others...
So basically the only thing separating the integra LS/RS/GS from the GSR and Type R is that the GSR and ITR has a vtec block and head?
SO if a person want to have VTEC in their non-vtec integra, all they need is a vtec head?
Old Aug 8, 2005 | 07:44 PM
Preferio's Avatar
Default Re: (pat00gsr@yahoo.com)
Ok... It's not that simple... you will need many other parts for it to be done correctly... the minimal items you will need are this... vtec head, vtec dizzy, vtec intake manifold, vtec controller, vtec ecu(or rpm activated switch), vtec oil line kit, a few other small things... Or, you could go into the Integra FAQ and look at it... and know everything there is to know about it...
Old Aug 8, 2005 | 07:50 PM
Default Re: (95IntegraLSR)
Ok, thanks man
Old Aug 8, 2005 | 07:51 PM
Preferio's Avatar
I may have come off as a dick, if so sorry... Long Day! But, most people on HT come off this way..l. A lot of them are! Others aren't... Have fun in the FAQ! Great information in there....
Old Aug 8, 2005 | 07:54 PM
Finger Lickin' good's Avatar
its not simple at all if you want to keep up with honda quality. But ya, youve got a long way to go noobie...You must use the search, just read and read and read, you will learn a lot faster than asking "what type of engine is ls/vtec...
And to answer your question, its a b18b or b18a block (1990-2000 integra) with a vtec head, either from a b16(civic) or b18c(gsr or ITR) vtec head. However, usually a complete rebuild of the motor will be in the course of action when doing this job. Its not required, but if you want the full potential.
Old Aug 8, 2005 | 08:02 PM
Default Re: (D-CeReaL#4)
Well, we all have to start somewhere. I'm only 19 with my first honda (GSR) and really wanted to learn about engine and stuff. But advice taken.
Old Aug 8, 2005 | 10:00 PM
LS_teg's Avatar
its cool dude, im building a ls v/tec motor right now. you need a good bit of ****. first you need a v/tec head b16,gsr,itr. then you need a vtec ecu, vtec dizzy. You'll need to find a Ls/vtec conversion kit Goldoneagle makes a good one. You'll need a new oil pump, water pump, timing belt. and theres alot more to it
And get it done by a pro its alot better you dont have to worry about ****** anythin up, and hopfully if he makes a mistake he will fix it free of charge
Have fun learnin about Honda motors you have a really long way to go and so do I
Peace!!!
Old Aug 8, 2005 | 10:12 PM
ONISHIMA's Avatar
Default Re: (LS_teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LS_teg &raquo;</TD></TR><TR><TD CLASS="quote">its cool dude, im building a ls v/tec motor right now. you need a good bit of ****. first you need a v/tec head b16,gsr,itr. then you need a vtec ecu, vtec dizzy. You'll need to find a Ls/vtec conversion kit Goldoneagle makes a good one. You'll need a new oil pump, water pump, timing belt. and theres alot more to it
Peace!!! </TD></TR></TABLE>
THATS SOME REALLY GOOD HELP MAN!!! btw to the guy who made this thread you said you CANT find anything about ls/vtec? thats alot of bs...CANT you google?? jus type anything into google i bet you that you would find it!! ya jus gotta have tha
passionates!!
Modified by ONISHIMA at 7:31 AM 8/9/2005
Old Aug 10, 2005 | 06:26 PM
LS_teg's Avatar
Default Re: (ONISHIMA)
posted by: ONISHIMA
passionates!!
thats true dude you can find anything at google.com, or you can just search on honda-tech.
goodluck on you searchin
Old Aug 10, 2005 | 06:35 PM
Bonty's Avatar
i just recently purchased my car from another driver and i found out that i have a ls vtec motor :D
Old Aug 16, 2005 | 02:38 PM
LS_teg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bonty &raquo;</TD></TR><TR><TD CLASS="quote">i just recently purchased my car from another driver and i found out that i have a ls vtec motor :D</TD></TR></TABLE>
well then your one lucky **** cause im going through alot to get mine ls/tec and then after i get that done im gonna build the block and boost.
TaptOutTokyoB18
Jan 24, 2006 06:32 PM
RSNTEKRA
Oct 3, 2005 10:58 AM
DOHC VTEC EG
Apr 26, 2004 11:39 PM
RSVTECDC4
Jul 19, 2003 06:05 AM
Steve-o
Jan 28, 2003 08:14 AM
