noob question
Old Jan 10, 2008 | 02:00 PM
matmcg's Avatar
Default noob question
i hear a quiet ticking sound while accelerating what could this be ??? also sometimes i have a weird bump in my idle while im waiting at light not often but everyonce in a while
Old Jan 10, 2008 | 02:01 PM
BlueIntegraBoy's Avatar
Default Re: noob question (matmcg)
Under harder acceleration? Sounds like detonation.
Old Jan 10, 2008 | 02:02 PM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: noob question (BlueIntegraBoy)
valves
Old Jan 10, 2008 | 02:07 PM
matmcg's Avatar
under ANY acceleration , it is not a loud ticking but i can hear it with music off
Old Jan 10, 2008 | 02:47 PM
clean3two3's Avatar
Default Re: noob question (GRAF-FITI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRAF-FITI &raquo;</TD></TR><TR><TD CLASS="quote">valves</TD></TR></TABLE>
x2
Old Jan 10, 2008 | 02:54 PM
lostshootingstar's Avatar
I would start with getting a valve adjustment, and if that doesnt help you can try other options.
Old Jan 10, 2008 | 03:07 PM
Byaaah!'s Avatar
Jet Life Til' The Next Life
Default Re: noob question (lostshootingstar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lostshootingstar &raquo;</TD></TR><TR><TD CLASS="quote">I would start with getting a valve adjustment</TD></TR></TABLE>
I second this, best thing to start off with...
Old Jan 10, 2008 | 03:38 PM
91whiteZCrex's Avatar
Default Re: noob question (Byaaah!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Byaaah! &raquo;</TD></TR><TR><TD CLASS="quote">
I second this, best thing to start off with...</TD></TR></TABLE>
BYaahh to that, if its not the valves, how often do you change ur oil? and what do you use?
Old Jan 10, 2008 | 03:48 PM
khurrum's Avatar
You totally scared everyone with that last response...not the place to ask when u change oil lol...
firstly get to a mechanic and get a valve adjustment and and possibly check your throttle body (clean it)
change oil every 4000km or earlier depending on how hard u drive. use w.e oil u want. i use Castrol
Old Jan 10, 2008 | 03:49 PM
khurrum's Avatar
i love how im the noob...
Old Jan 10, 2008 | 04:05 PM
steveo135's Avatar
Default Re: (khurrum)
Its probably not this because it would be more of a knocking than ticking but check your oil level... if its low that could be your problem
but I say valves also
Old Jan 10, 2008 | 04:22 PM
abraminho17's Avatar
Default Re: (steveo135)
valves or wheel bearings
Old Jan 10, 2008 | 04:34 PM
K2sInteg98's Avatar
Default Re: (abraminho17)
most likely vavles. Need a valve adjustment. Its often the result of mis-shifting or revving too high.
Old Jan 10, 2008 | 05:26 PM
Canadian also , he didnt even say how many miles it has on it
Old Jan 10, 2008 | 05:37 PM
scottland221's Avatar
VALVE ADJUSTMENT
Old Jan 10, 2008 | 05:53 PM
matmcg's Avatar
how does everyone know i live in canada, and btw how much does valv adjustment run me...
Old Jan 10, 2008 | 07:55 PM
jhammond_82's Avatar
Reject Papi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abraminho17 &raquo;</TD></TR><TR><TD CLASS="quote">wheel bearings </TD></TR></TABLE> i doubt the wheel bearings are making noises while sitting at a light. i agree with the others, check the oil and get a valve adjustment. ftw.
Old Jan 10, 2008 | 08:06 PM
GRAF-FITI's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abraminho17 &raquo;</TD></TR><TR><TD CLASS="quote"> wheel bearings </TD></TR></TABLE>
wow
Old Jan 10, 2008 | 08:35 PM
VTEC_PRODUCTION's Avatar
Default Re: (GRAF-FITI)
wow</TD></TR></TABLE>
LOL you need to adjust for the proper valve lash. its common for honda engines to get that ticking noise after so many miles...i dont mean so many by alot i mean so many as in certain amount.
Old Jan 10, 2008 | 08:45 PM
matmcg's Avatar
can i adjust it my self?
Old Jan 11, 2008 | 04:30 AM
92teginsc's Avatar
Default Re: (matmcg)
yes you just need the specs on how much to adjust.
Old Jan 11, 2008 | 07:54 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matmcg &raquo;</TD></TR><TR><TD CLASS="quote">can i adjust it my self?</TD></TR></TABLE>
yes there is a diy on it somewhere or you can buy a haynes or helms manual which you should have one already...
Old Jan 11, 2008 | 08:00 AM
GRAF-FITI's Avatar
* B A N N E D *
do you know how to use a feeler gauge?
Old Jan 11, 2008 | 08:33 AM
im pretty sure if you search on here you might find a DIY on valve adjustment, if you dont wanna do it yourself, then pay a shop to do it, it definatly shouldnt be more than an hour labor,
De_tour
10
Feb 5, 2007 06:14 PM
thaiphob
Dec 2, 2005 01:15 PM
ITR198
Nov 23, 2005 02:52 PM
Lshatchy91
Jun 5, 2004 09:38 AM
david90
Aug 8, 2003 06:25 AM
