no vtec
Old Nov 17, 2007 | 02:01 PM
adamrich33's Avatar
Default no vtec
i just picked up a 96 gsr yesterday and the vtec will not engage, when i test drove it the day before it hit vtec once. the only mods are a aem v2 cai, skunk2 im and a obx header. there is no cel's what could be the problem what do i need to look for
Old Nov 17, 2007 | 02:09 PM
hatchling37's Avatar
Default Re: no vtec (adamrich33)
How do you know VTEC isn't engaging? With a Skunk2 IM, you might not hear the engagement point like you would if it had the stock IM.
Old Nov 17, 2007 | 02:14 PM
Rickdrizzle's Avatar
vtec is probably kicking in at such a low rpm that you won't be able to hear it.
Old Nov 17, 2007 | 08:49 PM
Kirk GS-R's Avatar
check how much oil you have
Old Nov 17, 2007 | 08:51 PM
Acuronda_SloTeg's Avatar
Check your oil and also get a test light to the vtec solenoid connector. other than that i dont know. but like they said, aftermarket IM might be sucking the sound up.
Old Nov 18, 2007 | 02:10 AM
JerkDC2's Avatar
Default Re: (Acuronda_SloTeg)
OIL or you car is not warmed up.. very cold no vtach
Old Nov 18, 2007 | 10:04 AM
adamrich33's Avatar
the test light is only going to show voltage when im in vtec right? and the oil is fine and temp is fine to i waited until its fully warm before i drive past 5k rpm
Old Nov 18, 2007 | 10:07 AM
adamrich33's Avatar
Default Re: (adamrich33)
only thing i have to compare my gsr's vtec is to my brothers si. all he has is a header and you can definetly here the vtec. i would think with a im and header vtec should be more noticeable since its breathing better
Old Nov 18, 2007 | 10:58 AM
EJ1 Type Slow's Avatar
i have a gsr and with a skunk2 IM i hear vtec better...but then again i also have skunk2 cams.
Old Nov 18, 2007 | 12:23 PM
Schister66's Avatar
Man U FTW
bring it slowly through 1st gear....take it through 6k on light throttle and see if you can hear a difference in the engine tone. If you're hitting VTEC, it should be rather noticeable
Old Nov 18, 2007 | 12:28 PM
7mile's Avatar
Default Re: (Schister66)
check the OIL
Old Nov 18, 2007 | 12:59 PM
adamrich33's Avatar
Default Re: (7mile)
just figured it out. at 4400 rpms at about quarter throttle you can hear it. its more noticeable in 3rd than all the other gears but i hear it but nothing like my bro's si. i have been trying to hear it at full throttle but at 1/4 throttle you can hear it
Old Nov 18, 2007 | 01:03 PM
Schister66's Avatar
Man U FTW
^^that's how i tell if its working or not on my GSR. If you give it barely any throttle, and bring it through the RPMs, you can hear the switch. I have an easier time because my HP Racing IM is a VtAk microphone
Old Nov 18, 2007 | 01:49 PM
adamrich33's Avatar
apreciate all the tips and opinions guys, thanks
vietnogi
Apr 13, 2005 10:01 PM
vietnogi
Mar 6, 2005 12:14 PM
BlckSI
Aug 29, 2003 06:48 PM
civic596
Feb 3, 2003 09:46 PM
gsrhatch530
Mar 28, 2002 01:36 PM
