No start
Alright so this is a new build lsv turbo. When I put it together I accidentally ordered and installed the wrong throttle body gasket, the gasket didn't fit and would leak by the map and cause it to run 9 on the wideband. I ordered the correct one installed it and it just crank doesn't start. I tried starting fluid and still nothing. If I put the wrong gasket back in it will start. I'm thinking it's got somthing to do with the map because it only starts when the map is leaking. And help? It's a skunk2 68mm throttle body and pro intake with a hondata 4 bar map. Car is only base mapped so I can work out any kinks in it
I didn't remove the tps nor map sensor plugs while swapping gaskets. I've also called and talked to skunk2 who pointed out to me the correct gasket I needed. First image is the wrong gasket on the throttle body as you can see the port to the map isn't covered so allows it to leak the second image is the correct gasket I installed that covers the port
No mines on the same way just mine has a extra hole added to the one your showing. You got the 4 mounting holes and the 2 that go on the tps side that's it. That's the way I have it mounted. Skunk2 said it's the correct one along with other people who have the same intake and throttle body
The 70 and bigger gasket use different holes for some reason states that it's not for the 68mm pro. I ended up getting a alpha series gasket which is the one that doesn't cover it. I looked at other people that have the pro intake and 68mm throttle body and they use the 6 hole gasket and there's is fine. There is a channel in the throttle body thathen the gasket doesn't cover
EjSex
15
Aug 11, 2010 12:09 PM
patrick4588
Engine Management and Tuning
Aug 9, 2008 05:20 PM
