No crank
Hey all car is a 97 integra rs with a b20b auto trans in it and the car will not crank unless I jump the starter with a screwdriver, replaced or added all new grounds, replaced any associated fuses, main relay, and when you turn the ignition everything comes on on the dash and you can hear the fuel pump prime but will not crank at all but jumped with a starter car runs fine and shuts off fine, wondering if it is my ignition? But not really wanting to spend 300$ or so on a new ignition if it's just a bad wire I could've missed any tips or ideas would be appreciated, thanks! Running out of ideas
Test the whole ignition circut, look up a wiring diagram, start at the fuse, go down the line, relay solenoid, ignition switch, netrual safety switch ect. Youve just gotta find either what componet isnt working, or find where you,re loosing power. LOOK UP A WIRING DIAGRAM!!!
you got this
you got this
lingochad
14
Oct 15, 2012 04:00 PM
