Next Mod advice
Old Jun 8, 2009 | 09:07 AM
katanamast279's Avatar
Default Next Mod advice
I have a 95 LS 4 door Auto with a CAI, and Exhaust system.
My Hp goal is to get close to 200 HP
Or to run close to VTEC power.
I was looking for some advice to increase the performane of my teg.
Although i doubt that i could afford a manual swap.
Any suggestions?
How should i approach this?
Thanks alot
Old Jun 8, 2009 | 11:18 AM
GSRShane's Avatar
Default Re: Next Mod advice
Well, you have more flow going into the motor and more flow going out . . . why not improve what the motor is doing with that? Go with new cams, throttle body and a tune so the motor puts more gas with all that air.
Old Jun 8, 2009 | 12:56 PM
I was kind of thinking of doing some performance internal parts. Like pistons, etc.
I thought that aftermarket CAM's are illegal. And I've heard that throttle bodies only give you a slight HP gain. Also that the tune probably wound have minimal effects
Old Jun 8, 2009 | 02:36 PM
MilanoRedDashR's Avatar
Building an LS engine All motor is just not worth it. If you want to run with the big boys your going to need to blow way too much money (and even then I dont' know what you can do to an LS because I'm not into non vtec) or go boost. IMO you should just save up for Boost, or do a swap.
Old Jun 8, 2009 | 03:02 PM
yoontim23's Avatar
Any suggestions?
Thanks alot
It's going to be hard to hit 200 when you can't even afford a manual swap.
Old Jun 8, 2009 | 03:53 PM
Oh yeah, I didn't even realize it was Automatic... dude, you're in over your head. Impossible.
Old Jun 8, 2009 | 04:04 PM
babiboidb1's Avatar
yeha man your outta luck there. If auto an manual went at it with the same EXACT parts, you wouldnt have the same power for ****. Go to a junk yard and do a BACKYARD conversion AUTO to MANUAL swap. <----- Thats your first goal
Old Jun 8, 2009 | 08:37 PM
vinceg143's Avatar
how much are one of those swaps roughly i never looked into it but always wanted to know i heard someone say its not even worth it just buy a manual
Old Jun 8, 2009 | 08:52 PM
dc2_916's Avatar
you shouldnt be racing with a automatic anyways..
Old Jun 9, 2009 | 06:55 AM
TonyRomo's Avatar
ITR swap.
Old Jun 9, 2009 | 06:59 AM
Dogginator's Avatar
Daisy... Daisy...
This.
Old Jun 9, 2009 | 09:07 AM
theazndog's Avatar
sell yor ls get a gsr
Old Jun 10, 2009 | 05:44 AM
dntnedvtec's Avatar
Automatic = can't drive a stick. Or to lazy to drive a manual. Get a manual, then build a car. If you want to build a automatic racer, be prepared to be laughed at. Let me be the first: hahahahaa......J/K Go get yourself a manual pal. Then I help.
azzda
Feb 10, 2008 06:27 PM
durfeec
Nov 6, 2007 06:27 PM
xXxDelSoulxXx
Nov 3, 2006 09:34 PM
Teg3833
Jul 8, 2006 08:58 PM
96civich22
Aug 5, 2004 07:10 PM
