Newbie Nitrous Question
Old Mar 27, 2003 | 10:16 PM
cichlid's Avatar
Default Newbie Nitrous Question
I have a 96 gsr with: aem cai, dc 4-1 header, 5zigen exhaust (no cat),act clutch kit,xact flywheel,vafc. I would like to put a 50 shot of nitrous on it but i am new to nitrous. i heard the nx wet kit is a good choice. What do you reccomend I get? With the current modifications on my car will i need anything else to be safe? Yes i searched first
[Modified by integra121083, 7:18 AM 3/28/2003]
Old Mar 28, 2003 | 09:38 AM
B16Ej1's Avatar
Default Re: Newbie Nitrous Question (integra121083)
i dont believe in n20, but if your internals are not somewhat built, i would stay at 50 shot, just dont get button happy, or you will regret down the road
Old Mar 28, 2003 | 09:50 AM
neo1z's Avatar
Default Re: Newbie Nitrous Question (cream)
Okay - to actually answer your question
I would get a dry kit if you are only going to spray 50 - and 50 is where id stay. If you want to spray higher, I would consider the Nos plate kit for the GSR. Zex or Nos is fine dry-wise. Zex is much easier to install, so I personally would get that.
If you were going to shoot 50, all I would do is get one step colder plugs, and I would retard the timing a degree or two. Youll be fine if you do that..
Old Mar 28, 2003 | 09:58 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Well i've been down the nitorus road and did not have 1 problem. The best bet for you will be to get a Zex Kit. www.zex.com or you can call 1888-817-1008 ask for Joey. Tell him Antwon sent you. he will direct you in whatever you need. If you have questions you can call me 817-528-8231 or im me. Good luck.
Old Mar 28, 2003 | 10:04 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: Newbie Nitrous Question (neo1z)
That is wrong info. I hate to knock him but it's wrong. You need 2 steps colder if you don't want the plugs to go out all the time. Trust me i went from NGK 6 which fell through to sevens which are still going now. Don't get the Zex plugs. They did not work out good for me nor my friends. That's the only things i don't like about Zex. Also with a 50 shot. There is no need to touch the timing. Leave it normal.
Old Mar 28, 2003 | 10:38 AM
964dgsr's Avatar
Default Re: Newbie Nitrous Question (HybridcivicLS-T)
How bout at 75 is it still ok to leave timing at stock?
Old Mar 28, 2003 | 11:26 AM
btl fed's Avatar
Default Re: Newbie Nitrous Question (964dgsr)
I have installed the ZEX kit twice, and each time it went smoothly...If you want to upgrade from a 55 shot to a 65 shot or a 75 shot you have to retard your timing by 2 degrees. There should be no problem w/ running a 75 shot w/ some cam gears as long as you don't use it too much. I am getting my cam gears installed next month and then am going to start spraying 75 shot....w/ just an intake and exhaust so far
Old Mar 28, 2003 | 11:35 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
No that's not ok, it's a 6degree retard.
Old Mar 28, 2003 | 11:37 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
No that's not ok, it's a 6 degree retard.
Old Mar 28, 2003 | 11:46 AM
btl fed's Avatar
How bout at 75 is it still ok to leave timing at stock?No that's not ok, it's a 6 degree retard.
ZEX tells you to retard it only 4 degrees...
Old Mar 28, 2003 | 12:47 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: Newbie Nitrous Question (btl fed)
Thanks for the correction. It's been a while scince I looked at those simple instructions.
02Civicking
Jan 3, 2006 10:52 AM
fastacurachick
Mar 4, 2003 06:11 PM
ViperRedCRX
Feb 14, 2002 07:37 AM
ViperRedCRX
Feb 14, 2002 06:19 AM
