Never seen this one before...
Old Mar 13, 2008 | 03:19 PM
BoSox46GSr's Avatar
Default Never seen this one before...
Well, today I got a new axle, (passenger side, 94 GSR) and I noticed that it wouldn't go all the way in. It would get to the splines, and no further. It was lined up perfectly. Then I put my finger in there and there was a rod that was coming down diagonnally stopping the axle from going in any further. I've never seen this before, and I've done my fair share of axles. Has anyone ever run into this problem before? I'm sorry I don't have pics, no access to camera.
Old Mar 13, 2008 | 03:28 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Never seen this one before... (BoSox46GSr)
Are you talking about the pin for the spider gears, which runs through the center of an open differential?
Old Mar 13, 2008 | 03:33 PM
BoSox46GSr's Avatar
Default Re: Never seen this one before... (Dogginator)
I would assume that's what it is. I've never seen it before though, or maybe I just haven't been paying attention in the past. But I've never had an axle that just wouldn't go in.
Old Mar 13, 2008 | 03:36 PM
Dogginator's Avatar
Daisy... Daisy...
Measure the hole depth and then measure how deep the axle is going in.
Old Mar 13, 2008 | 03:40 PM
BoSox46GSr's Avatar
I basically did, I used a screw driver and i put it up to the pin and held my thumb right at the opening. I moved the screw driver down to the shaft with my thumb in place, and my thumb was right at the end of the splines, and there was still a few more inches to go before it would be completely in. If i place the axle in up to that point and then put my finger in between, the gap is about enough for about 1-2 fingers.
Old Mar 13, 2008 | 03:44 PM
Dogginator's Avatar
Daisy... Daisy...
DO you have the old axle for comparison? Perhaps you were given the wrong one.
Old Mar 13, 2008 | 03:48 PM
BoSox46GSr's Avatar
Yeah I have it, it's the right axle. I work at NAPA, we have three different brands of axles, we had one in stock, the other two I ordered, matched them all up to the old one and they're all the same. I thought it was the wrong one too.
Old Mar 13, 2008 | 05:01 PM
BoSox46GSr's Avatar
BUMP...Open for suggestions
Old Mar 14, 2008 | 02:47 PM
BoSox46GSr's Avatar
Bump....
Old Mar 14, 2008 | 07:17 PM
g2daturbo's Avatar
plain and simple sounds like the wrong axle..i worked at napa a few yrs back and there axles are horrible and there listings are even worse..... double check it again....
Old Mar 14, 2008 | 08:15 PM
ivan93egreppin210's Avatar
Default Re: Never seen this one before... (g2daturbo)
does your old axle go back in?
Old Mar 14, 2008 | 08:34 PM
jeffy's Avatar
Default Re: Never seen this one before... (ivan93egreppin210)
its just not seating past the retaining clip. slide it back a little and stab it in pretty hard youll feel when its in properly. new clips are tough to pass sometime.
Old Mar 14, 2008 | 11:03 PM
BoSox46GSr's Avatar
Default Re: Never seen this one before... (jeffy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g2daturbo &raquo;</TD></TR><TR><TD CLASS="quote">plain and simple sounds like the wrong axle..i worked at napa a few yrs back and there axles are horrible and there listings are even worse..... double check it again....</TD></TR></TABLE>
The Axle I got is a Napa Max Drive 94-6009... right part number I believe because I checked in sales history and all of those axles went out for integras and never came back defective or anything.
Old Mar 16, 2008 | 09:15 AM
BoSox46GSr's Avatar
OK... well its definately not the wrong axle, I just need to know if there should be anything in there that would stop the axle from going any further. Its a metal piece coming down about the size of my thumb from what I can tell. It's about 3/4's of the way in where the axle goes into the tranny.
Old Mar 16, 2008 | 11:06 AM
BoSox46GSr's Avatar
Bump
Old Mar 16, 2008 | 11:09 AM
Dogginator's Avatar
Daisy... Daisy...
Is the retaining ring on the axle bigger than the old one? That could make the insertion difficult.
Old Mar 16, 2008 | 11:16 AM
BoSox46GSr's Avatar
No, there's no difference in axles at all... it's just that piece that i can see that's blocking the axle from going in any further that I've never seen before.
Old Mar 16, 2008 | 12:03 PM
BoSox46GSr's Avatar
http://s270.photobucket.com/al...r/Car/
got a picture of waht seems to be in the way.
Old Mar 16, 2008 | 05:11 PM
BoSox46GSr's Avatar
Has anybody ever seen that before???
Old Mar 16, 2008 | 06:16 PM
ls19integra95's Avatar
YES, thats supposed to be there, that means you dont have a LSD transmission.
as some one else asked, does your OLD axle go in completely???
Old Mar 16, 2008 | 06:56 PM
BoSox46GSr's Avatar
Default Re: Never seen this one before... (ls19integra95)
Old axle doesn't go back in... but thanks for letting me know that that is supposed to be there... i guess i'll just beat the hell outta this thing untill it goes in all the way! THANKS EVERYONE
Old Mar 16, 2008 | 07:22 PM
all-mtr-teg's Avatar
Are the splines in good shape, I can't tell from that photo? A buddy of mine had his axle pop out, and that damaged the splines so even a new axle wouldn't go in.
Old Mar 16, 2008 | 07:40 PM
g2daturbo's Avatar
Default Re: Never seen this one before... (all-mtr-teg)
hit up my cell bro im pmd u my number i live 5 minutes away... im always down to give u a hand
Old Mar 16, 2008 | 09:02 PM
siksdb8's Avatar
I had a similar problem with my 95 GSR. i just grabbed a 3 lb baby sledge and tapped it in
integrainside
33
Oct 1, 2013 11:28 PM
spotrep
Transmission & Drivetrain
Jan 24, 2013 06:54 PM
SPOOLINmatt
Jan 25, 2006 05:15 PM
Mavrick
Nov 11, 2005 11:14 AM
HondaPartsHero
May 22, 2005 09:25 PM
