need some advice
my clutch went out on my 92 ls and i'm currently shopping around. ive found a clutch kit on ebay for about $253 including shipping. This complete clutch kit includes:
Exedy Pressure Plate (Made in Japan)
Exedy Clutch Disc (Made in Japan)
Release Bearing (Made in Japan)
Pilot Bearing
Alignment Tool
the flywheel that comes with the kit is about 7.5lbs and is aluminum. i only pln on making about 250 - 300 horses out of the teg. my questions is have n e of u used a flywheel like this n did u have n e problems with it. i forgot to metion its a fidanza flywheel if that makes a difference. the teggy is going to be used mostly on the w/end for fun but i still want it streetable just in case. n e feed back will be greatly appreciated n thanx in advance.
Pilot Bearing
Alignment Tool
I use the same clutch and its great...i would rethink using such a light flywheel though AND the fact that is aluminum would bother me a bit. I run an ACT 11lb fly in my GSR with the Exedy 2 and haven't had any problems with it after 2 seasons of 315whp/216wtq
prostreetonline
Oct 19, 2006 01:10 PM
prostreetonline
Jul 24, 2006 05:32 PM
