Need quick help, changing tranny fluid.
Old Nov 11, 2007 | 07:59 AM
bcrosby51's Avatar
Default Need quick help, changing tranny fluid.
I am changing my tanny fluid because A, I have a slow leak, B, I don't know the last time it was changed and C, I have a high RPM 3rd gear grind. I have search and found different opinions on fluid types. I was just going to O'Reillys and get some tranny fluid. What is the best kind to get? They don't carry anything called GM Syncro Mesh, that is was I was going to get.
Old Nov 11, 2007 | 08:31 AM
myfirstdc2's Avatar
Default Re: Need quick help, changing tranny fluid. (bcrosby51)
u can ge teh pennzoil syncro mesh
Old Nov 11, 2007 | 10:17 AM
g3integragsr's Avatar
* B A N N E D *
Use Honda MTL. It is designed to work with our transmissions and does an amazing job.
You can get it at the dealer (honda or Acura) for about $5 a quart. You will need three quarts.
If your grinding isn't to bad at this point, the new fluid will help out tremendously
Old Nov 11, 2007 | 11:46 AM
supracrx's Avatar
second to using honda MTF.
but why dont u fix the leak first?
Old Nov 11, 2007 | 05:07 PM
matsgsr's Avatar
Default Re: (g3integragsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g3integragsr &raquo;</TD></TR><TR><TD CLASS="quote">Use Honda MTL. It is designed to work with our transmissions and does an amazing job.
If your grinding isn't to bad at this point, the new fluid will help out tremendously</TD></TR></TABLE>
I found this out when i didn't use this for my lsd equipped itr trans. The fluid has friction reducer in it and worked instantly.
Old Nov 11, 2007 | 05:27 PM
PACT man's Avatar
Default Re: (matsgsr)
I third the Honda MTF, only thing I run in my Honda trannies.
Old Nov 11, 2007 | 07:08 PM
clean3two3's Avatar
i have problem c. lol.
Old Nov 12, 2007 | 04:37 AM
bcrosby51's Avatar
Default Re: (supracrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by supracrx &raquo;</TD></TR><TR><TD CLASS="quote">second to using honda MTF.
but why dont u fix the leak first?</TD></TR></TABLE>
I don't feel like pulling the tranny to fix it. It looks like there is a hairline crack in the case which I suspect it is leaking from. It really isn't a bad leak or anything. If the car sits for a week or so, there is a stain about the size a jar lid on the ground. I really don't plan on having the car too much longer.
So, I think I will use the Honda fluid. Is it the fluid that goes in the car or do you have to ask for it specifically?
Old Nov 12, 2007 | 07:47 PM
* B A N N E D *
Its called Honda MTL (manual transmission lubricant)
It is used in all honda manual transmissions.
Old Nov 12, 2007 | 08:10 PM
goheel's Avatar
Honda MTL is more than $5/quart. I use Penzoil synchromesh and it works great, no more grinding.
Old Nov 12, 2007 | 08:29 PM
WanaBeFaster's Avatar
O'reilly sells Royal Purple Synchromax. It works good.
Old Nov 16, 2007 | 10:38 PM
clean3two3's Avatar
not to threadjack but changing the transmission oil can only one person do it themselves or do you need 2 ppl?
Old Nov 16, 2007 | 10:49 PM
bigkvn77's Avatar
Default Re: (clean3two3)
its definetly a one person job. Its just like changing the oil.
Old Nov 26, 2007 | 08:18 PM
Agent_EM1's Avatar
Default Re: (bigkvn77)
is royal purple syncromesh any good?
Old Jan 3, 2008 | 06:55 PM
cody93's Avatar
try the crush washer on the drain plug and you can use pennzoil syncro mesh or gm dont matter or just 40 weight motor oil which it calls for in the owners manual
CRP
Nov 5, 2017 01:06 PM
Peteypablo17
Feb 18, 2013 11:21 AM
purple98ek
Jun 6, 2007 06:18 PM
lamboextreme
Jan 2, 2007 07:31 PM
onyx00
Oct 27, 2001 07:56 AM
