Need lots of help
Old Feb 4, 2006 | 01:12 PM
tunerchris17's Avatar
Default Need lots of help
I just bought a 95 GSR coupe but the guy I bought it from was a complete moron and drove the car almost completely into the ground and now I don't even know where to start (I guess I should have known not to buy a car from a guy who had eagle alloys and an cheap *** muffler on an Integra...dumbass) But anyway I've got a B18C1 engine that may as well be a geo moetro engine. the car has no acceleration at all. If I push the gas all the way down the car shakes and pulls back on me so I have to granny accel just to keep the car form shaking apart. I think it may be the fuel system but if anyone can think of anything different let me know. If replace the fuel system what type of system should I go with? Should I replce everything or just certain parts, what do you guys think? Also has anyone else had sever brake problems with a GSR? My ABS fluid leaks out somewhere and I have to refill it every week. I've had the car a little over a month and I've already had to replace the front pads twice. The Motegis I threw on it are completely ruined already because of the brake grime. Any suggestions on this one, short of replacing the whole brake system what should I try? Could this all be related to the ABS problem?
Old Feb 4, 2006 | 01:23 PM
Moshimoto racing's Avatar
Default Re: Need lots of help (tunerchris17)
how much u pay for this thing?
Old Feb 4, 2006 | 02:12 PM
wytechoppin's Avatar
ok dude your brake fuild leaking .. check under neath the driver consule.. and see if its leaking from the inside... and if not then check all the line that lead from and away from you brake fuild res. and you bogglinh ect change your fuel filter.. also look at the spark plugs. and distributer. let me what you find...
Old Feb 4, 2006 | 02:14 PM
Default well...
Old Feb 4, 2006 | 02:22 PM
teg racer 877's Avatar
Default Re: well... (wytechoppin)
how many miles on it? how much did you pay? what you need to do is a major tune up, Distributor cap, rotor, plugs, wires, fuel filter, air filter, change oil, pvc valve, injector cleaner, and clean the inside of the intake mani. if it has alot of miles, and get a new o2 sensor is it has alot of miles.
as for the leaking brakes, check all ur lines and find where its leaking and tighten or replace.
crazyhouse2011
42
Mar 25, 2013 03:39 PM
M2B4
Feb 29, 2008 06:56 PM
PrjktSol
Jul 7, 2005 09:05 PM
MooreBoost
Nov 11, 2002 07:33 PM
