Need Help!!!! Wire Harness??
Old Aug 17, 2006 | 09:52 PM
coolguy660's Avatar
Default Need Help!!!! Wire Harness??
Modified by coolguy660 at 2:02 PM 9/9/2006
Old Aug 20, 2006 | 03:32 PM
2Point2EH2's Avatar
Default Re: (coolguy660)
the dash harness... connects to your cluster, fuse box, radio, climate control,ect..
Old Aug 22, 2006 | 06:37 AM
Lan's Avatar
Lan
The dash harness does on both sides of the firewall, the inside and outside of the car. Both ends of the dash harness connect at the firewall. So, the wiring inside the engine bay, (wires to ABS, lights, fuse box, fan etc) is also considered the dash harness.
You may be able to buy the engine bay part. But I doubt it.
<----------Had to replace the whole harness before, it's a PITA.
Old Aug 30, 2006 | 03:27 PM
Lan's Avatar
Lan
If you cannot find one, PM me. You can use mine but You'll have to solder a **** ton of wires, and rewire a couple things
Old Aug 30, 2006 | 09:45 PM
coolguy660's Avatar
Default Re: (Lan)
Coo......
thanks
ParistsCP
May 7, 2006 07:16 AM
hybridpatient95
Oct 7, 2005 08:18 AM
highmilehatch
Jul 23, 2003 07:48 AM
