need help with timing on a b18a1
ok i took the frint cam out to find one of the little nuts that holds down the lifters it would crank and run good before i put the cam back right i tryed to crank it and now it wont crank so whats the easyest way to time it
you ran the car with only one cam??? Is that what i am reading???<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90si_mugen_crx »</TD></TR><TR><TD CLASS="quote">it would crank and run good before i put the cam back right i tryed to crank it and now it wont crank so whats the easyest way to time it </TD></TR></TABLE>
Are the cams set to TDC?? If so you need to make sure the crank pully timing marks line up with the timing makr on the block/timing cover
no i didin run it with one cam it ran good be for i took the cam out .............so if the bottom dosent line up, then it got out of time when i tryed to start it
Civicman86
Jun 22, 2006 10:01 AM
EKB18BPR3
Dec 25, 2003 03:21 PM
Tommy_Gunns
Aug 23, 2002 03:07 PM
Black R
Jul 20, 2002 10:31 PM
