Need help with power window
Old Sep 4, 2007 | 06:22 PM
dubs97integ's Avatar
Default Need help with power window
Ok, so my passenger window wont roll back up! Piece of ish. Anyway, I tried researching it but was no help. It started by going up slower than the driver side for a while now. And now it wont even got up a little bit or make any kind of noise. I did check the fuses and they seem fine. Anybody experience this before? I need you guys, help me out. Thanks.
Old Sep 4, 2007 | 06:34 PM
Mfoehrkolb's Avatar
your motor is probably bad. i replaced my pasenger side motor, and now it goes up fast then my drivers side. --- they overheat sometimes and then sieze up. or just go bad. try jumpstarting the motor and see if it moves. check switchs and relays too.
Old Sep 6, 2007 | 06:26 AM
OLD-HONDA's Avatar
Default Re: (Mfoehrkolb)
I had the same problem, you need a new regulator: it was way too expensive for me at the factory-go to junkyard
xz1236
Nov 2, 2014 11:51 PM
RGoose18
Aug 28, 2009 10:39 PM
DonReggeaton
Jun 16, 2009 07:39 PM
Neptronix
Aug 31, 2007 06:55 PM
super jdm yo
May 30, 2006 01:19 PM
