need help getting the name of a part!!
What is the sensor on the throttle body called? Because i am swapping out a 91 b18a into a 93 shell and i already switch the wiring harnest from obd0 to 0bd1 but the plug on the throttlebody sensor is diffrent and the fuel injectors too. So im going to to just buy new fuel injectors and a new sensor but i dont know the name of the sensor. Can anyone help me out
throttle postion sensor.... they are the same between 90-93 integra.. take a pic so we know what ur talking about.... injectors are obd0 90-91 and obd1 92-93 can be found used pretty easily..gonna be very costly new... i have a nice set if ur interested!
well i found out wat was goin on today with the wiring wat happend was that the dumb *** "mechanic" that was doin the swap for me got and automatic wiring harnest insted of a manual harnest ..... :/
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aeenox »</TD></TR><TR><TD CLASS="quote">What is the sensor on the throttle body called? Because i am swapping out a 91 b18a into a 93 shell and i already switch the wiring harnest from obd0 to 0bd1 but the plug on the throttlebody sensor is diffrent and the fuel injectors too. So im going to to just buy new fuel injectors and a new sensor but i dont know the name of the sensor. Can anyone help me out
TPS is on the throttle body and the MAP sensor is on the firewall. Since you are using a OBD-0 B18A and swapping it into a OBD-1 chassis. You either need the injector harness from the old engine wiring harness or get OBD-1 fuel injector harness.
</TD></TR></TABLE>TPS is on the throttle body and the MAP sensor is on the firewall. Since you are using a OBD-0 B18A and swapping it into a OBD-1 chassis. You either need the injector harness from the old engine wiring harness or get OBD-1 fuel injector harness.
