need help fast!!!!!!!
Old Apr 26, 2006 | 08:23 AM
Silent_Destruct's Avatar
Default need help fast!!!!!!!
i am replacing my pass side axle and i just finished but now it doesnt even go into gear! i pushed it in as far as i can but it doesnt seem to want to sit flush with the tranny. any ideas? did i miss something???? please help! tuts are helpful too!
Old Apr 26, 2006 | 08:37 AM
Default Re: need help fast!!!!!!! (Silent_Destruct)
bump please
Old Apr 26, 2006 | 08:39 AM
Lan's Avatar
Lan
Is it a stock axle?
Old Apr 26, 2006 | 08:41 AM
oh yea it is a stock axle
Old Apr 26, 2006 | 08:49 AM
Lan's Avatar
Lan
Default Re: (Silent_Destruct)
Pull it back out... it needs to sit almost flush with the tranny case. It should slide it pretty easily if the teeth are lined up correctly.
Old Apr 26, 2006 | 08:55 AM
it doesnt seem to go in all the way, and the teeth are lined up because its turning inside.....but then i put it back together and i can go through every gear and it wont move an inch.
like i said the teeth lined up and i push it as far as i can, but it doesnt sit flush. shoudl i try hammering it witha rubber mallet? it shouldnt be this hard right?
Old Apr 26, 2006 | 09:01 AM
Lan's Avatar
Lan
Sometimes it is stuck but I would not hammer on it yet. Try pushing really friggin hard casue sometimes it acts like a bitch. If that doesn't work I would look at the axle again to make sure you have the correct one. Count the splines on the axle and the tranny. Did you replace the clutch or something? Or just the axle? The last thing you want is to start hammering on it if it is not the right part.
Old Apr 26, 2006 | 09:32 AM
just the axle. and does neone have pics of it next to trans in it?
bandaid
Mar 29, 2011 05:36 AM
Kyle244R948
Aug 17, 2009 07:04 PM
hatcht9x
23
Nov 10, 2008 05:26 PM
t0ekn3e
23
May 15, 2005 06:44 PM
sLoWrAcEr
Jan 17, 2005 08:27 AM
