Need help!! Extremely stumped...
Old Mar 22, 2010 | 07:39 PM
clewis3's Avatar
Icon3 Need help!! Extremely stumped...
My Integ will crank but won't start. It died on me while on the highway and now will not start. I was told by my dads friend it was an issue with the ignitor or ignition coil because it wasn't getting any spark, so i got them tested and both were bad, along with the dizzy, so I replaced it. Slapped the new dizzy in and the car still won't start and still will not get any spark. Any ideas?? I'm about ready to push the damn thing over a cliff!!
Old Mar 22, 2010 | 07:53 PM
egsleepercivic's Avatar
Default Re: Need help!! Extremely stumped...
is the fuel pump turning on, have you check the main relay
Old Mar 22, 2010 | 08:12 PM
clewis3's Avatar
Yeah the fuel pump turns on, when i modded the engine I upped my fuel pump and put a kill switch near the wheel, when i turn the key and and hit the switch you can hear the pump switch on and put fuel to the engine. And no i haven't checked the main relay, how do you recommend i do that? just the "3clicks test'?
Old Mar 22, 2010 | 08:15 PM
stocker2shocker91's Avatar
I requested a short story for a title.
any codes?
Old Mar 22, 2010 | 08:18 PM
clewis3's Avatar
nope. no codes, no check engine lights nothing. just cranks and no spark.
Old Mar 22, 2010 | 08:46 PM
if the fuel pump is priming its ok
Old Mar 22, 2010 | 08:48 PM
sohc eg's Avatar
sounds like a typical honda distributor taking a ****. try borrowing a known working distributor...if thats not it maybe the timing belt jumped a tooth
Old Mar 22, 2010 | 09:05 PM
TehGhett0P1mp's Avatar
Try another dizzy if you have one around, im going through the same **** right now. Hopefully your issue is easier to track down than mine..
Old Mar 22, 2010 | 09:07 PM
clewis3's Avatar
I just slapped a new dizzy on it, and when the thing crapped out on me on the highway I noticed that it had jumped time, so I replaced the timing belt thinking that was the original problem, but still no start. I'm telling you guys, this thing is really puttin me through the ringer.
Old Mar 22, 2010 | 09:17 PM
if the timing belt jumped you probably want to do a compression test and a leak down test, you may have tweaked the valves
Old Mar 22, 2010 | 09:18 PM
clewis3's Avatar
how would i go about that? haven't done that before
Old Mar 22, 2010 | 09:26 PM
clewis3's Avatar
cuz dont i need to the engine to be able to run in order to do a comp test?
Old Mar 22, 2010 | 09:39 PM
it just needs to turn over, search here and you will find how to do it
gl
Old Mar 23, 2010 | 09:17 AM
redpreludesi's Avatar
ya i had the same problem it was my ignitor but i just bought a whole new dist. cuz i plan to keep my car
Old Mar 23, 2010 | 09:30 AM
clewis3's Avatar
yeah i did too, but it still doesn't work... fml
Old Mar 23, 2010 | 09:44 AM
even if it jumped a tooth and tweaked a few valves it would still make an attempt to fire and pop and make some racket.i had a no start situation with my 98 integra and it turned out to be the ignitor (no codes were thrown when it went out)
maybe try and get a cell phone vid or something for us to listen to for maybeother possible issues
Old Mar 23, 2010 | 10:56 AM
slo_hatch's Avatar
ok so 5+ people say their ignitor went bad...if you bought a NEW dizzy then it should have a warranty...try trading it out for a new one and try it again. thats your best bet.
Old Mar 23, 2010 | 11:09 AM
clewis3's Avatar
It wasnt starting with THE OLD BAD IGNITOR AND DIZZY. I had both of those tested and they were bad, SO I BOUGHT A WHOLE NEW DIZZY. I PUT THE NEW DIZZY IN AND THE CAR STILL WON'T START.
Old Mar 23, 2010 | 11:11 AM
clewis3's Avatar
I also heard AGC Fuse??
Old Mar 23, 2010 | 11:16 AM
slo_hatch's Avatar
ok...so take the new dizzy back and get another one then try again. not a hard concept. and im not sure what the agc fuse is. the ecu/ecm fuse will disable the dizzy from creating spark and wont tell the fuel pump to spray fuel to the engine.
Old Mar 23, 2010 | 11:18 AM
sohc eg's Avatar
Let me say this again:
Try a known working distributor.
Those advance auto/autozone **** units sometimes don't work and/or dont come with a coil/ingniter
Old Mar 23, 2010 | 11:20 AM
dudesitsjdm's Avatar
did you get a new dizzy or a oem rebuild one?Ive heard alot of people say that the NEW dizzy are crap and u have to keep trading it in till you get a good one.Alot of people say to stick with an oem rebuilt dizzy.
Old Mar 23, 2010 | 11:23 AM
slo_hatch's Avatar
3 bolts...line it up the way the old one was and BAAMMM your done. not hard. this is the easiest thing to do to test it. then return your "new" dizzy and get another new one if its bad.
Old Mar 23, 2010 | 11:32 AM
nokturnal_munkeeboy's Avatar
he said replace the dizzy... hey to hit your starter with a rubber mallet.. some problems with hondas are the starter because metal pieces are rusted and need to be cleaned. try that and see if that works first, if your car doesnt start then something else is wrong
Old Mar 23, 2010 | 11:41 AM
it cranks over, thats not the issue ^^^
