Need help with Check Engine light.
Old Jan 11, 2002 | 03:56 PM
Got-VTEC's Avatar
New User
Default Need help with Check Engine light.
This is my first check engine light and I am not sure how to read the code. I mean I followed the procedures and the check engine light blinked 9 times in the same one second pattern, then there was a pause and it repeated itself.
Here is the problem. On an ODB II ECU there is a code for 9 and one for 90. I am not sure which on the 9 blinks comes out to, just the 9 or is the 9 the first number and the pause a 0.
If anyone can help it would be very helpful. Thanks in advance.
9-Cylinder position sensor intermittent interruption or no signal
90-EVAP system leak detected in fuel tank area or in canister area.
Old Jan 11, 2002 | 05:02 PM
gsxr's Avatar
Default Re: Need help with Check Engine light. (Got-VTEC)
check this http://www.team-integra.net/ti/faq/ecu-codes.asp
Old Jan 11, 2002 | 06:23 PM
rockwilda's Avatar
Default Re: Need help with Check Engine light. (gsxr)
what mods do you have on your car? it will help a little bit
Old Jan 11, 2002 | 08:48 PM
Vtec integra's Avatar
wish i could help but my luck hasn't been that bad yet
Old Jan 12, 2002 | 05:23 PM
Got-VTEC's Avatar
New User
AEM CAI
DC 4-1
Apex N-1 & VAFC
Skunk 2 Cam Gears & Manifold
Old Jan 12, 2002 | 05:24 PM
FSTASNTZ's Avatar
Did you do a certain mod or routine work right before the light came on?
Jason
Old Jan 13, 2002 | 09:36 AM
rockwilda's Avatar
im pretty sure with those mods its a code 90. i threw it after i installed my Skunk2, check all your vacuum hoses and make sure your EVAP lines are all connected clean and not kinked. also you can check your fuel cap to see if its closed tight.
Old Jan 13, 2002 | 01:09 PM
Got-VTEC's Avatar
New User
Yeah I just had my Skunk 2 installed like 2-3 weeks before the light came on. I am just going to take it back to the tuner shop that installed it. The owner is cool with me and should take a look at it.
Thanks again.
cooltool
Aug 15, 2011 07:56 AM
G. Man
12
Feb 25, 2011 06:13 PM
99gsrboosted
Apr 13, 2007 06:44 PM
slvr98
Jun 10, 2005 10:13 AM
