Need help car is having issues idle.
Hey guys been a long time, been really busy with my jobs and my Integra. She is a manuel and when i first start her, my idle is fine and is until Operating temp.At first As soon as it hits operating temp my idle surges up and down, and almost dies. I get a check engine for a TPS code P0122 i think but i replaced my tps sensor 3 times still no difference. I have also checked for vaccum leaks but have found none. Also checked the tps and wiring and it loks fine, Things i noticed though are.. Now it Dies at idle 95% of the time.
One: Throttle Body cable/where cable connects is sticky..
Two: My Idle is really ****ed up now, at 90% of lights when i idle my car dies and its only running at 480-520 RPMS
Is it the Map sensor, or Idle control valve? Need some help, i was thinking about picking up a Map sensor at My Autozone today and trying it. Howver it says 3 door Integras and 4 door map sensors are different??!! I thought they were the same?
Thanks for the help guys..
Check engine codes are: P0107, P0108, PO122
Map/Baro CKT Low input, Same thing but also high input, andthrottle/pedal position sens a ckt Low input.
i believe your throtle body needs to be adjusted theres a small litle screw that adjust the the throtle plate you will see it once you look close also i believe your tps must be recalibrated but its verry simple just get a volt meter and look up how to do it.
Ok what is/was wrong
Map sensor was dead/dying
Throttle body was sticky as hell now fine
I have a BIG *** vaccum leak somwhere. (had to go to work so had no time to look) going to tommarow morning.
gabrielsousa
May 19, 2014 04:23 PM
I Like Hondas
Jun 11, 2006 05:35 PM
AllMTRWH0R3
Aug 4, 2004 03:40 PM
