Need help with cams
Old Jun 24, 2006 | 07:05 AM
EJ8 GSR-T's Avatar
Default Need help with cams
I am doing a GSR turbo build, and my mechanic lost my cams! Now he found some skunk 2 turbo cams, 305050155 is the part number. So i am wondering how these work, and i cant afford new springs and retainers, but i dont plan to rev to high.
Old Jun 24, 2006 | 07:33 AM
mr.beeks's Avatar
Default Re: Need help with cams (EJ8 GSR-T)
turbo cams have longer duration no high lift like NA cams...
so you will be OK
Old Jun 24, 2006 | 07:35 AM
EJ8 GSR-T's Avatar
Default Re: Need help with cams (mr.beeks)
so what kind of advantages will i see over stock cams?
Old Jun 27, 2006 | 11:24 AM
EJ8 GSR-T's Avatar
bump
Old Jun 27, 2006 | 11:42 AM
scB20teg's Avatar
Get a set of ITR/CTR cams if you can, or just go with stock GSR cams. They work much better than turbo specific cams. Search around for dyno sheets, many people are making high horsepower with stock B-series cams.
Old Jun 27, 2006 | 11:44 AM
lVlemphizStylez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.beeks &raquo;</TD></TR><TR><TD CLASS="quote">turbo cams have longer duration no high lift like NA cams...
so you will be OK</TD></TR></TABLE>
dont you mean turbo cams are short duration high lift?
long duration cams increase overlap (which is what youre trying to get away from in a turbo charged engine)...high lift is what can net the more horses without necessary shifting the powerband...
Modified by lVlemphizStylez at 12:56 PM 6/27/2006
Old Jun 27, 2006 | 12:24 PM
DC2SIR-G's Avatar
* B A N N E D *
Default Re: Need help with cams (lVlemphizStylez)
i would personally go with the CTR cams. they cost much cheaper than turbo cams and i believe there is dyno plots showing that they also make more power then the turbo cams. stick with b series cams
Old Jun 27, 2006 | 01:19 PM
EJ8 GSR-T's Avatar
Default Re: Need help with cams (DC2SIR-G)
****, well the deal is my mechanic lost my stock GSR cams, so he got this set of skunk2 turbo cams.....so am i gettin screwed?
Old Jun 27, 2006 | 02:49 PM
Sam92Teg's Avatar
Your probably getting a good deal, turbo cams should be better for your turbo application than stock cams.
Old Jun 27, 2006 | 02:55 PM
scB20teg's Avatar
Default Re: Need help with cams (Sam92Teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam92Teg &raquo;</TD></TR><TR><TD CLASS="quote">Your probably getting a good deal, turbo cams should be better for your turbo application than stock cams.</TD></TR></TABLE>
Turbo cams aren't better in this situation.
Read this... http://forums.evans-tuning.com...=1623
Old Jun 27, 2006 | 03:27 PM
yee SERIOUS's Avatar
correct. picking a cam is like picking a turbo. you gotta have the right one for your setup and obviously don't over do it.
if your mechanic lost your gsr cams, then take his Skunk2 turbo cams and put them up for sale. gsr cams are dirt cheap. but personally i would recommend you get some ITR cams and some aftermarket adjustable cam gears.
itr cams &gt; gsr cams &gt; b16 cams
Old Jul 21, 2006 | 11:02 PM
EJ8 GSR-T's Avatar
Default Re: (undercoverdc2)
thanks
Natural Aspirations
Jan 19, 2011 05:01 PM
85mmek9
Oct 31, 2007 10:44 AM
gsr_pimp88
Oct 20, 2006 01:44 PM
rocket256
Aug 25, 2003 09:04 PM
