Need Help with Cams!!!
Old Oct 14, 2004 | 05:18 AM
acuratuner00's Avatar
Default Need Help with Cams!!!
I've heard that the best cams for the b18b1 are crower cams and cam gears...
do you guys have any other suggestions and also where I can find the cam gears?
I found the cams on the website...but not the gears. Thanks for any info!
Old Oct 14, 2004 | 05:43 AM
W.O.P.'s Avatar
Default Re: Need Help with Cams!!! (acuratuner00)
https://honda-tech.com/zerosearch
Old Oct 14, 2004 | 10:58 AM
i got some info.....
any other suggestions would be helpful...thanx...
i just want to know which are the best cam gears to use with the crower cams.
Modified by acuratuner00 at 3:11 PM 10/14/2004
Old Oct 14, 2004 | 05:46 PM
anybody???
Old Oct 14, 2004 | 06:06 PM
jdmotorsports's Avatar
Default Re: (acuratuner00)
i like the skunk2 cam gears. thats what i use/recommend. also for cams i like either crowler or web cams. both make nice sticks.
Old Oct 14, 2004 | 06:09 PM
boosted k20's Avatar
all cam gears function the same way. one wont give u more power than the other. it's just the design of the cam gears are different. some are held on by 3 screws like AEM's and some with more like the SKUNK2's which have 6 screws. More screws are better becuase it prevents the gears from slipping. I have Crower 62403's with SKUNK2 cam gears.
if ur getting cams for your car, then get the Crower 62403's or the 62404's WITH the valvsprings and retainers!!!!! make sure u do that. u can go with any set of adjustable cam gears
da_all_day
May 29, 2011 09:45 AM
MDintegra95
May 5, 2005 08:28 AM
DrewQ1
Mar 7, 2004 05:03 PM
