need help with brake light
Old May 31, 2011 | 04:00 PM
hershy253's Avatar
Default need help with brake light
not sure if its a wiring issue or anyone else has had this problem but my tailights reverse lights head lights all work but when i press on the brake the brake lights wont come on tested all the fuses and checked the bulbs anyone know what the problem might be? this is on a da9
Old May 31, 2011 | 04:23 PM
fcm's Avatar
fcm
Old Fart
Default Re: need help with brake light
Check brake light switch. 94
Old May 31, 2011 | 04:35 PM
hershy253's Avatar
how can u tell if it is bad or should i just replace it?
Old May 31, 2011 | 06:54 PM
Oreo-TeCk's Avatar
pull the bulbs first and inspect them... 1 filament can be bad..if they are good change brake light switch
Old Jun 1, 2011 | 05:36 AM
fcm's Avatar
fcm
Old Fart
Unplug the brake switch and jump the two leads in the plug, [white/green and green/white] if brake lights work replace switch. 94
Old Jun 1, 2011 | 08:35 AM
hershy253's Avatar
thx guys got it replaced this morning and everything works!!!
Xzay01
Lighting
Jun 14, 2013 08:53 AM
TomCurllyFry
Mar 25, 2013 09:29 PM
Zac W.
Apr 2, 2012 08:45 PM
Egpower88
Nov 5, 2009 01:12 PM
wakaba_db1
Jul 8, 2005 12:44 AM
