need help adjusting headlights
ok i need to adjust my headlights i have a 94 integra with 2000 bumpers and HID lights... the high beams are pointing up and i want to bring them down i see the level that the headlights have is all the way up i went on team-integra.net and i saw how u adjust them.. the problem is that when i turn the **** to adjust the lights it just turns and does not move does anyone know what the problem could be and how can i fix them...
First off are you trying to get your high beams to the level your low beams are at? The answer is you can't. They are attached together inside the housing. Second, I thought the same that no matter how much I turned the adjustment **** it did not adjust the lights. Keep turning until you think you can't anymore and then keep going. Or attach a Phillip's bit to your drill and use that to turn them. It will adjust them I promise. Don't go crazy with the drill though, go slow.
Make sure you are turning the right ****. The one that is closest to the fenders is the side-to-side adjustment. The **** that is in between the low and high beams is the up-down adjustment.
yes i was turning the right one but nothing was happening the lever is still all the way up.. i guess im going to have to try with the drill when i get home today to see if that works..
J1A1H
Apr 10, 2006 10:24 AM
b18bme
Sep 18, 2004 07:13 AM
