Need Help with 98+ CD player.
Old Oct 20, 2005 | 01:39 PM
RicharDC4's Avatar
Default Need Help with 98+ CD player.
well, when i got my car back from the shop, my stock 98 cd player was flashing "code". and i thought i remembered the code and started punching in numbers.
i did it three time and now it wond let me enter the code anymore. it now displays "Err-3"
i consulted my 96 car manual and it said that if you fail the code 3 time, you should leave it on for one hour and try again. my car originally came with a cassette player.
well i did that and it is still displaying Err-3. im assuming that for 98+ theres a different method to let me enter the code again?
can anyone with a 98 car manual look it up and tell me? thanks in advance.
Old Oct 20, 2005 | 02:38 PM
t0ekn3e's Avatar
disconnect your battery for a few mins.
Old Oct 20, 2005 | 02:39 PM
pat.ter.rick's Avatar
time for an aftermarket headunit.
Old Oct 20, 2005 | 02:48 PM
RicharDC4's Avatar
Default Re: (t0ekn3e)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0ekn3e &raquo;</TD></TR><TR><TD CLASS="quote">disconnect your battery for a few mins.</TD></TR></TABLE>
i thought about that but its too much of a hassel. there must be an easier way.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsR_vteC &raquo;</TD></TR><TR><TD CLASS="quote">time for an aftermarket headunit.</TD></TR></TABLE>
im not really of a sound guy so im fine with the stock one. plus, it loooks good already.
Old Oct 20, 2005 | 03:50 PM
v-tecgoswahn's Avatar
Default Re: (RicharDC4)
uh happen to me too i jus unplugged the stereo for a few minutes and plugged it back in. And you need the code off the car that that particular stereo came in
Old Oct 20, 2005 | 04:35 PM
shyboy817's Avatar
You're putting in the wrong security code, I believe if you just turn the radio on and off it'd let you re-enter the code, or unplug the harness in the back...either way if you don't have hte code call acura.
Old Oct 20, 2005 | 06:10 PM
RicharDC4's Avatar
Default Re: (shyboy817)
i do have the right code. it was just that when i got the car back from the shop, i thought i remembered the code so i punched in the code while on my drive back home.
Old Oct 20, 2005 | 06:36 PM
shyboy817's Avatar
So did you get it working now?
Old Oct 20, 2005 | 10:43 PM
RicharDC4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shyboy817 &raquo;</TD></TR><TR><TD CLASS="quote">So did you get it working now?</TD></TR></TABLE>
yea got it working. but i was hoping to know another way that i can reenter the code without unpluging the system or the battery..
Old Oct 20, 2005 | 10:58 PM
cloudx71's Avatar
well unpluging the battery is easy as poping yoru hood going to the bat and unpluging the neg terminal for like 5 seconds, its not that hard. Aside from that i dont think theres any other way. also you can just go to acura to try and get code, although my acura asked for my actual headunit so they could check. goodluck.
Old Oct 21, 2005 | 06:07 AM
BlackSage's Avatar
Default Re: Need Help with 98+ CD player. (RicharDC4)
The only way i know how to do it is to unplug the radio in the back.
Old Oct 21, 2005 | 06:55 AM
shyboy817's Avatar
Normally if you push the **** to turn off the unit and push it again to turn on, you should be able to re-enter the code. You don't have to re-enter the code unless you unplug your battery, or unplug the harness on the back of the head-unitt
Coreatown
Aug 12, 2008 01:53 PM
yspech
Sep 16, 2005 01:43 PM
EuN_TeK
Feb 27, 2004 07:08 PM
Integra97Zeke
Audio / Security / Video
May 18, 2002 05:34 PM
