in need of a fix for code 9 and 17 on OBD0 Integra, please help
Old Sep 24, 2010 | 12:48 PM
94DCTeg's Avatar
Default in need of a fix for code 9 and 17 on OBD0 Integra, please help
Hello members, I picked up a DA for 150 dollars, the body is actually in good condition, anyways I drove the car and it drives fine, the car has adjustable cam gears, cams(not sure the brand) header and exhaust, anyways, I cleaned up the car a little and noticed that the CEL does not come on when the car is started, so I checked the cluster and the bulb was taken out, so I decided to check the codes on the ECU and it is giving me code 9 ( CYP Cylinder sensor) and code 17 VSS, is there an easy way to fix code 9 ?? I have searched and found nothing on the fix, I dont know why the previous owner didnt convert to OBD1, but I guess he was not thinking, if anyone could please help me with the code 9 fix that would be awesome!! the motor is a b18b1 if that matters ?
Thanks
Thomas
Old Sep 24, 2010 | 03:34 PM
94DCTeg's Avatar
Default Re: in need of a fix for code 9 and 17 on OBD0 Integra, please help
30 views and no answer or fix ??
pureclass69
Mar 16, 2011 09:19 AM
bababab18
Sep 30, 2010 01:30 PM
