Need Cams
Old Feb 18, 2007 | 07:32 AM
Byaaah!'s Avatar
Jet Life Til' The Next Life
Default Need Cams
What kind of cams should I get, how much should I expect to pay, and how much power will I get? I drive a 95 LS
Old Feb 18, 2007 | 09:46 AM
SlammedDC2's Avatar
Semper Fidelis
Default Re: Need Cams (Project95LS-VTEC)
what is your set up, how much do you have to pay, how much power do you want to gain
Old Feb 18, 2007 | 01:54 PM
doood's Avatar
been there done that
Default Re: Need Cams (SlammedDC2)
jdm stage 5's. $900. 104hp exact.
seriously, how do you expect to get a resonable answer when you provide no usefull info.
Old Feb 18, 2007 | 05:10 PM
1337whp's Avatar
he's right your answer is vague, b18a/b's arent the best motor for N/A, unless your planning to make it vtak. imo if i had a ls. if the compression was fine and it was a healthy motor i'd leave the internals stock and boost the bitch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">jdm stage 5's. $900. 104hp exact.
Old Feb 18, 2007 | 05:11 PM
martyball619's Avatar
Default Re: Need Cams (1337whp)
boost tha bitch
Old Feb 19, 2007 | 05:11 PM
acura1808's Avatar
u should get bloxs those are the **** they pull hard
Old Feb 19, 2007 | 05:22 PM
doood's Avatar
Default Re: Need Cams (acura1808)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acura1808 &raquo;</TD></TR><TR><TD CLASS="quote">u should get bloxs those are the **** they pull hard </TD></TR></TABLE>
your intelligence is beyond recognition
Old Feb 19, 2007 | 05:24 PM
aaronISthrowed's Avatar
Default Re: Need Cams (doood)
More info plz
Old Feb 19, 2007 | 06:28 PM
mystikalstriker's Avatar
run a search ^ ^
Old Feb 19, 2007 | 06:44 PM
qwk db8's Avatar
Default Re: Need Cams (mystikalstriker)
just remove the head ur car will be faster who needs cams anyway all that damn head does is make ur car heavy and slow.lol
Old Feb 19, 2007 | 07:33 PM
E.J.'s Avatar
わたしは。。。
Default Re: Need Cams (qwk db8)
You wont find a lot of help with your question being so vague...but I'll try to point you into a direction.
Cams will vary depending on your desired setup. Putting cams depends on how much power you are looking for, how the car will be driven, where you want the power to be, etc...
If you are looking for cams just to put in the car without anything else on it, you wont see much of a difference. Basically, you can have a built head and/or built bottom end as well to compliment the cams.
I dont personally know what cams work well with B18B1s, but just do a search and I;m sure a ton of results will pop up.
booget
19
Mar 10, 2008 01:16 AM
lsteg94
Sep 4, 2007 01:48 PM
DC2SIR-G
Mar 16, 2006 04:34 PM
Beau Gotti
Feb 22, 2006 08:57 PM
got_boost16
24
Jan 27, 2006 12:26 PM
