more power..?
well i've been debating... i want a bit more power, i want to be sure to hit mid 13's... right now, my list of mods is:
gsr block, .25mm overbored type r spoon balanced pistons, type r shotpeened rods, type r knife edged crankshaft, b16 head, skunk2 stage2 cams, skunk2 retainers/springs, 5 angle valve job, skunk2 IM, jdm itr tranny (4.785 final drive), act heavy clutch/lightened flywheel, cylinder wall honed
it's an all motor beast, and i haven't taken it to the track yet, so i'm not sure what it would run.. hondata s200 just came in, and it hasn't been tuned at all, so i figure i should get a bit more power once i do... soooo should i stay all motor, and if i do, what else can i do to get some more decent power?? i don't want to shave anymore weight, it's a very daily driven car.. if i don't stay n/a, here's my other idea..
https://honda-tech.com/zerothread?id=542559
edit: forgot to add, it's got 110k on the motor, but all of the work was done last year, ~20k miles ago... that's why i'd feel more safe staying n/a.
if you want to stay n/a then defintely keep your engine, and get it tuned. it doesnt look like you have any fuel relatedproducts, fuel pump, larger injectors, those would help and i would think that you would be able to hit mid 13s with that setup.
tempsohc
14
Oct 30, 2006 07:47 PM
bleedblue94
Sep 11, 2006 08:01 AM
