Misfire problems PLEASE HELP
I have been in the garage for the last couple of days tryin to figure out what is goin on with my GSR. Its a 200+whp all motor setup. A couple of days ago rite outa the blue the car started to misfire at 1500-3000rpm then took off like nothing happened. It doesnt do it all the time. I am completely baffled over this. I checked everything from igniton to electronics and there are no problems... So I turn to you guys for help
Thanks....
Thanks....
Mods...
HEAD: Port and Polish, AEM Tru Time Cam Gears, SKunk2 Valvetrain, SKunk2 High Compression Valves, SKunk2 Stage 2 Camshafts
BLOCK: Bored 20 over, Edged and Polished Crank, Eagle H Beam Rods, Endyn High Compression Pistons, Balanced and Blueprinted
Air/Fuel: V-AFC Apexi Controller, Skunk2 Type R Manifold Conversion with Type R Throttle Body, AEM Cold Air Intake, RC 310cc Injectors, B&M Command FLO FPR
Exhaust: DC JDM 4-1 Header w/ Test pipe, 2.5 inch cat back.
I don't see that you changed anything with your ignition system for all that extra HP. Don't you need different plugs when you create more HP?
sleepycivix
Dec 28, 2002 09:08 AM
sleepycivix
Dec 18, 2002 08:30 PM
sleepycivix
Dec 18, 2002 04:53 PM
