a misfire problem
I have a 98 b18b in my civic coupe and I'm having a misfire issue.
Basically whenever I start the car after it was been warmed up (and sometimes on cold starts) the car misfires and it goes away once I start driving it which is kind of strange and doesn't ever misfire again until the car is turned off and back on. I changed the plugs so far but what else could be the problem?
i have the same problem but a lil worse underload the car seems like its runing on 3 cylinders. i change my entire dizzy plug wires and the plugs and even the fuel filter and i still have the problem
o2 sensor is most likely the issue if u have tried the distributor.. usually a dsitributor wont do that.. they'll just go out.. but sometimes they act up a lil first.
Good luck
Good luck
aight truu kus for sum reason when i was at the track my car sounded like it was misfiring every thousands rpms like 6k 7k 8200 and that both wit old dizzy and the new one
