Mirror Install
How do you install Spoon mirrors on a DC? I have been trying for a little bit now but I cant get the door panel far enough out of the way so I can get to the screws. I have searched but havent found any real helpful information. Pictures would be GREAT....
Make sure you remove the one screw that holds in place the plastic piece containing the door lock switch. Then remove that piece.
They remove the one screw that holds in that little plastic handle. THen remove the plastic piece.
Then I usually start off at the bottom left corner of the panel, and snap off going along the edge of the door. Should come off.
Remember not to just pull that sucker out. You HAVE to unplug the speaker, door lock and window plugs.
After this, you remove the snap off black plastic piece on the backside of the mirror.
Be careful not to break it or bend it out of place.
this is the easiest way to do it.....you have to remove the door panels...which are easy to do...make sure you keep all screws together so you wont lose any....remove black plastic piece to get to 3 nuts.....unplug the harness for that is going into your side mirror...get 10mm rac or socket....unbolt all 3 nuts but make sure you are holding the mirror also so it wont drop or hit your car......install the new mirror...holding the mirror rebolt the 3 nuts and plug in the harness...you may have to puss the harness into the mirror alittle so that the black plastic will fit back on....then put door panel back on...fairly easy...
the window weather stripping....how the expletive did you do that......once you pop the door panel out push up on the door panel to unhook the part taht slides in the window/door frame...take your time....
graveltravel2
Dec 9, 2009 10:41 AM
