the math doesn't add up. Magic horespower!!
Old Jun 3, 2003 | 11:51 AM
95civichybrid's Avatar
Default the math doesn't add up. Magic horespower!!
ok so heres the problem. I bought a used 97 teg gsr and its fast. It came with aem cold air, cams, cam gears, dc header, tanabe racing medallion exhaust, lowered with 17s, neuspeed clutch. gsr's make 178 horses right? Well te thing is a raced to s2000's on the highway last weekend. I hung with both from 50 mph to about 145, and mean right next to them. The problem is, s2000's make 248 stock, they both had vafc, intake, header, exhaust, and ignition. If i'm conservative i give them about 280 hp. And if i'm generous with mine i would say i have about 230. I'm fairly sure a s2000 is lighter than a teg with two people, two 12" subs, and crap in the trunk. When we pulled over their jaws were hangin open and demanding i pop my trunk. So what the hell is up? I have a magic hp genie or what?
Old Jun 3, 2003 | 11:54 AM
fivespeedintegra's Avatar
Default Re: the math doesn't add up. Magic horespower!! (95civichybrid)
s2000 horsepower = 240
gsr horsepower = 170
CoryTurner's Avatar
the s2000 owner doesn't know how to drive..............u dont' have over 200 hp.....no way. u would be lucky with 170 with that setup u also loose way big amounts of hp in the drivetrain. most stock gsr's have 140-150hp on the dyno......with ur mods looking at 160-165
Old Jun 3, 2003 | 11:55 AM
95 Gizzer
Guest
Posts: n/a
Gsr - 170
S2000 - 240
You don't have near 230 unless you have some wild cams.
Old Jun 3, 2003 | 11:56 AM
AWDxBOOST's Avatar
Default Re: (CoryTurner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CoryTurner &raquo;</TD></TR><TR><TD CLASS="quote">the s2000 owner doesn't know how to drive..............u dont' have over 200 hp.....no way. u would be lucky with 170 with that setup u also loose way big amounts of hp in the drivetrain. most stock gsr's have 140-150hp on the dyno......with ur mods looking at 160-165</TD></TR></TABLE>
exactly....maybe he jus wanted to make u feel good
95 Gizzer
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CoryTurner &raquo;</TD></TR><TR><TD CLASS="quote">. u would be lucky with 170 with that setup </TD></TR></TABLE>
He's talking flywheel HP, and 170 is what he has stock
Old Jun 3, 2003 | 12:21 PM
AllmotorJunkie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95civichybrid &raquo;</TD></TR><TR><TD CLASS="quote">So what the hell is up? I have a magic hp genie or what?</TD></TR></TABLE>
Dats right! there is a magic HP genie hiding inside your engine. I have one too.
Old Jun 3, 2003 | 12:23 PM
Default Re: the math doesn't add up. Magic horespower!! (AllmotorJunkie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllmotorJunkie &raquo;</TD></TR><TR><TD CLASS="quote">
Dats right! there is a magic HP genie hiding inside your engine. I have one too.</TD></TR></TABLE>
lol
i always thought my car had gnomes...
Old Jun 3, 2003 | 12:38 PM
sutrusu's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95civichybrid &raquo;</TD></TR><TR><TD CLASS="quote">And if i'm generous with mine i would say i have about 230.</TD></TR></TABLE>
rofl
Old Jun 3, 2003 | 12:40 PM
jonoknut's Avatar
Default Re: the math doesn't add up. Magic horespower!! (sutrusu)
i think theres confusion with wheel HP and at the flywheel.. .
Old Jun 3, 2003 | 01:03 PM
metal-x's Avatar
Default Re: the math doesn't add up. Magic horespower!! (jonoknut)
JDM gsr makes 178 hp
Old Jun 3, 2003 | 01:12 PM
CoryTurner's Avatar
"He's talking flywheel HP, and 170 is what he has stock"
i was talking whp but even still a car with miles on it does not put out what the dealer says it will........
Old Jun 3, 2003 | 01:14 PM
streakz's Avatar
maybe he was cruising...and you think you're racing him
Old Jun 3, 2003 | 01:39 PM
BoxStuffer's Avatar
If you really want to know how much power you're making, go get your car dyno'd.
If you really want to know how fast you are, go to the track.
Old Jun 3, 2003 | 02:22 PM
neo1z's Avatar
Default Re: the math doesn't add up. Magic horespower!! (ekcoupe97)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekcoupe97 &raquo;</TD></TR><TR><TD CLASS="quote">If you really want to know how much power you're making, go get your car dyno'd.
Simple as that.
What cams are in your car?
Old Jun 3, 2003 | 02:30 PM
patdemps's Avatar
Default Re: the math doesn't add up. Magic horespower!! (neo1z)
You don't have magic horsepower. But there a chance you have one of those wednesday cars (factory freaks). Once you tell us your setup then we will know more about what you have for whp. Just telling us you have cams doesnt mean anything....you could have itr, ctr, jun, toda, skunk2.....the power ranges are all over the place. Once you find out whats in your ride then let us know. Im not surprised that you hung with a S2000, i've seen plenty of them go down to well modded cars. Plus i've seen a bunch with drivers that don't know where the pedal is (running 15.8's-16.6's at the track, haha). I've even seen a supercharged sk2 run a 14.9...not that impressive considering the car should run low 14's stock and some have run high 13's without even modding it. so it could very well be the driver. But its not like your car is slow, you should have quite a bit of lift with your setup..i say you hung with him because your car is fast and his was stock ...either way just find out about your car.
Old Jun 3, 2003 | 02:33 PM
patdemps's Avatar
Default Re: the math doesn't add up. Magic horespower!! (patdemps)
Also one more thing....when you pulled over the guys in the sk2's demanded to see what was in your TRUNK???.....why did they think you had a few fred flinestones in the back running along to make the car move quicker.....if they didn't know that the motor is under the HOOD then maybe thats why there cars stayed with you......
Old Jun 3, 2003 | 02:40 PM
ArizSun21's Avatar
From: Do I look like Michael Bolton from Office Space,, MD, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by patdemps &raquo;</TD></TR><TR><TD CLASS="quote">Also one more thing....when you pulled over the guys in the sk2's demanded to see what was in your TRUNK???.....why did they think you had a few fred flinestones in the back running along to make the car move quicker.....if they didn't know that the motor is under the HOOD then maybe thats why there cars stayed with you......</TD></TR></TABLE>
He's got NOS yo!
Old Jun 3, 2003 | 02:42 PM
patdemps's Avatar
Default Re: the math doesn't add up. Magic horespower!! (arizsun21)
if he had nos he shoulda run by them, not with them...especially with his mods...
Old Jun 3, 2003 | 02:51 PM
GSRwBOOST's Avatar
Default Re: the math doesn't add up. Magic horespower!! (fivespeedintegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fivespeedintegra &raquo;</TD></TR><TR><TD CLASS="quote">s2000 horsepower = 240
gsr horsepower = 170</TD></TR></TABLE>
flywheel
more like for the gsr is around 140-145whp and the S2k whp ??
Old Jun 3, 2003 | 04:28 PM
sutrusu's Avatar
Default Re: the math doesn't add up. Magic horespower!! (GSRwBOOST)
n.o.s. is a brand name, not a thing.
i live in the oosa
Old Jun 3, 2003 | 04:33 PM
n0 iNTegRiTY's Avatar
haha, most excellent. Where can i get one?
Old Jun 3, 2003 | 05:10 PM
Rory Breaker's Avatar
I love that out of all the responses, most people just hated on the dude and made fun of him because he didnt know what he was talking about.
Yet the key thing here being the Cams...only one person asked, "what kind of cams?"
Try giving some more helpful responses guys before just bashing people. Also, I find it hard to believe that someone can be such a poor driver from a roll...all youre doing is flooring it and shifting. It can be a number of things...sure you can have a "strong motor" but depending on maintenance of the cars, what cams youre running, how it was tuned, weight of the cars, etc etc...who knows. Way too many variables and not enough info to tell you.
The only way to find out, go to a dyno. Streetracing is not a tool for measuring horsepower
jdmspice
Honda S2000
11
Mar 22, 2012 08:37 AM
jmyers09
Feb 6, 2009 08:32 PM
VtecKiDD
Honda S2000
11
Aug 15, 2004 02:22 PM
AzN_Flava
Audio / Security / Video
Aug 17, 2001 06:33 AM
