MAP sensor question.
I'm having problems with a MAp sensor code. I have checked the wiring and the wiring is good. So this leaves me with the options of bad ECu tuning or Map sensor. Can I replace my map sensor with any OBD1 Map sensor?, or does i has to from an B18C1?
I really dont like that code...
Im having the same problem
with my DA! UGHHH!
You CAN use an OBD I
sensor...however
it will have to be tied up
in some way, as it
mounts to the TB...
unlike the DA where the
MAP is located on the firewall.
In my situation, changing
the map didnt work.
Hope this helps.
Good luck.
Modified by FuknHeeHAw at 3:09 PM 11/26/2006
with my DA! UGHHH!
sensor...however
in some way, as it
mounts to the TB...
the map didnt work.
Hope this helps.
Good luck.
