Mant. Required Light
My Mantenience Required light has been on for a while, and theres nothing wrong with my car, is there any special way of turning this light off? I heard there was a button underneath the steering wheel, but i dont see one.
Little blue button under the steering column on the right side, you can't miss it. After you turn your ignition on, hold it until the light goes out and then it won't come on again until your next scheduled maintenance.
there should be a little blue square button under ur dash by ur shins i guess. it should be on a little black box. look 4 that and it might be near the middle, not necessarily on the right.
put your hand on the panel below the steering column, and move it down till you reach the lower edge of the panel. Then move your hand to the right along that bottom edge and you should come to a box w/ a square button. When you first start the car, push and hold that button for about 10 seconds and the light will go out.
After 7500 miles the light will flash 10 times when you start the car, so just repeat the procedure again.
Your blind... It's not under the steering column, it's under the dash to the right of the stearing column - you really can't miss it!
If still cant find it bring it to my grandma she could probably find it - ;D
